global boost control + wgdc ?
Old Apr 11, 2016 | 06:17 AM
Cbr1000love's Avatar
Hello everyone. so im trying to tune but i keep getting different readings so i am guessing there is something that needs a little tweak. i use a mbc not ecu controlled but i looked at my global boost control settings and my boost error correction load map has numbers that do not make sense and if i switch the value it messed with the boost error correction psi map.
also i noticed when i hit boost the waistgate opens right away. i thought it was not suppose to open until i hit desired boost or close to it. if i go wot the wgdc goes to zero.
excel is rpm/boost/wgdc
Old Apr 11, 2016 | 07:11 AM
ridenrunwv's Avatar
If you use a manual boost controller that won't make a difference. The WGDC you're logging is what the ECU is commanding and not a value logged from a sensor.
Old Apr 15, 2016 | 05:20 AM
is that a map i am suppose to adjust? i would imagine not because it just goes off of vacuum.
Old Apr 15, 2016 | 06:12 AM
ridenrunwv's Avatar
If you are using a manual boost controller you don't need to worry about any of the boost control stuff. As far as I know those tables are to command different WGDC to an electronic boost controller and do nothing if you aren't using ECU boost control.
Old Apr 15, 2016 | 08:03 AM
RazorLab's Avatar
with a MBC it doesn't matter, the only table you need to adjust is the boost limit table
roni4g63
Nov 22, 2015 02:54 PM
domyz
Sep 9, 2014 10:48 AM
R/TErnie
Oct 29, 2008 02:54 PM
Jumperalex
Jul 4, 2007 03:03 PM
