S366 2.0 v7 Timing Map Help
Old Apr 18, 2016 | 12:12 PM
2winscroll's Avatar
Hey guys I'm in need of some help starting out with a safe timing map. Wanted to get my fuel ironed out before I go to the dyno, but want a safe timing map to start out on.
I'm on SD and currently have my Map VE set straight across the board, so it's 14.5lbs of boost at 200 load, and 29lbs at 300 load. Looking to push around 35lbs of boost maybe more, wanna see were this turbo runs out of steam. Hoping for 800, we will see.
Any help would be GREATLY appreciated.
Mods are as follows;
Built 2.0 10.5 comp
E85
S366 turbo twin scroll mani
Double pumper
Kelford 284HL cams
Coil on plug ignition
2150's
Tephra V7
Old Apr 18, 2016 | 03:35 PM
desiromeo812's Avatar
There is a thread with just timing maps. You should go take a look.
Old Apr 18, 2016 | 03:36 PM
CurseDSM's Avatar
Although I am not a tuner, I can tell you where the turbo runs out of steam. It stops right around the 50 lb mark.
Old Apr 19, 2016 | 08:00 AM
2winscroll's Avatar
I checked that thread and there are mostly stock turbo timing maps with stock compression motors. I'm looking for a starting point with 10.5 compression, big turbo. Nothing close after going through about 50 pages.
Only 50lbs eh?
Old Apr 19, 2016 | 02:49 PM
CurseDSM's Avatar
Originally Posted by 2winscroll
Only 50lbs eh?
Yeah 50 is about the max. I know a few people who run the 366 and its a bad *** turbo but on both their cars starts to lose steam right around 50 lbs. Being your higher compression you may be able to get away with more. Both the other cars are 9.5:1 and the other is built but is about 8.5:1. 800whp on that turbo I don't think you will be anywhere near 50lbs. 800 should be in the mid to high 30s depending on supporting mods
Old Apr 19, 2016 | 07:04 PM
2winscroll's Avatar
Not really wanting to guess, Hoping for 800hp on the Dyno leave it at that.
Any reliable info is appreciated.
mrevoix2006
Jan 22, 2011 02:09 PM
holiday63
12
Aug 5, 2010 09:31 PM
SBR INC
Aug 24, 2009 10:57 AM
SBR INC
Mar 12, 2009 09:24 AM
dsm25psi
Jun 25, 2008 04:29 PM
