FP BLACK - dead zone in spool
Subscribe
Jul 3, 2016 | 11:08 AM
I'm tuning a friends EVO8 old school BB FP Black but w/o surge ports / 2.0L / S2 / 110 leaded ....
When starting a pull from 2k rpms in any gear the car starts to accelerate then it feels like it pauses for a second before to boost kicks in and it takes off like a raped ape.
This happens in every gear, it feels almost like a full second of a stead state transition before rapidly building boost. The only config change from the last tuning session was a shift from HKS 272 to GSC S2 cams.
I tried trimming timing adding timing as well as fuel adjustments but there was no change in spool up behavior.
Any ideas on what would cause a dead spot in transition?
Reply 0
Jul 3, 2016 | 11:41 AM
If you have messed with timing and fueling and have not noticed a difference, its most liekly mechanical, id check the wastegate and make sure its not loose or anything funky like that, and maybe a boost leak test
Reply 0
Jul 3, 2016 | 12:04 PM
Mine used to do that, but it was the comp wheel hitting the housing. Turbo was toast. Hopefully your friend doesn't have that problem.
Good luck, brotha!
Reply 0
Aug 10, 2016 | 01:18 PM
why no surge ports?
what boost level are you targeting?
would be good to see the boost vs rpm trace
Reply 0
Subscribe
