Air and fuel ratios....
Old Mar 22, 2017 | 07:26 PM
Cmeix's Avatar
Unhappy Air and fuel ratios....
Hey, i was just wondering if anyone could maybe help me with my situation....
I just recently got my EVO 9 dyno tuned and everything. I live in Canada, so it gets pretty cold here and i daily drive the EVO as well.
What i have been noticing with my Air and Fuel ratios that when it gets real cold like in the negatives in Celsius, my air and fuel ratios begin to
RICHEN UP, not lean out but when it gets warmer my ratios LEAN out but not richen up...
So i was just wondering if anyone could kind of let me know what may be wrong with my car? Because i thought that when there is colder weather, your ratios should lean more than rich and when the weather warms up more it richens than lean....
HELP PLEASE !!
Old Mar 22, 2017 | 11:46 PM
4b11slayer's Avatar
Its probably going into open loop. And open loop usually is rich.
Old Mar 23, 2017 | 12:08 AM
RightSaid fred's Avatar
What mods to it?
If it's stock, there's nothing to dyno tune........all you're going to do is screw everything up.
Old Mar 23, 2017 | 06:46 AM
Cmeix's Avatar
Does that mean my car can also go into open loop when it's idling rich as well? I see my ratios go down to like high 12s on Idle on cold days... and even when I'm cruising, everything gets richer.
Old Mar 23, 2017 | 06:47 AM
Cmeix's Avatar
Originally Posted by RightSaid fred
What mods to it?
My motor is fully built, top and bottom end.
1000cc inj
gt30 turbo
all your bolt ons
etc, etc.
I don't see why i tune would screw anything up.
Old Mar 23, 2017 | 07:10 AM
4b11slayer's Avatar
If its so cold that the coolant temp drops im sure thats what it is.
Old Mar 23, 2017 | 07:14 AM
Cmeix's Avatar
Would there be a way to properly fix this???
Old Mar 23, 2017 | 07:22 AM
ronaldo9's Avatar
That is typically the behavior until the car has warmed up. If the car was tuned have the tuner look at the tables but this isn't necessarily a bad thing. What are the ratios exactly? What are your fuel trims like? Also are you running a regular thermostat or something like a mishimoto 63 degree thermostat?
Old Mar 23, 2017 | 07:54 AM
Cmeix's Avatar
I am running a normal thermostat with an upgraded mishimoto rad.
The behavior that i am talking about is AFTER everything is warmed up, and driven a little to basically get the car into warmed up temps.
My tuner touched upon the INJECTOR scaling, but it fixes the cold weather days but once it starts to get warmer, the car runs leaner than it should... So i find it weird.
My ratios at idle go down to like 12s on cold days, and also WOT is basically 10s... cruising speeds are in the 13s..
These are all on cold days, without tweaking anything on the tune..
Old Mar 23, 2017 | 10:05 AM
ronaldo9's Avatar
Are you on speed density or maf?
Old Mar 23, 2017 | 11:11 AM
Cmeix's Avatar
I am on speed density.
Old Mar 23, 2017 | 09:50 PM
4b11slayer's Avatar
Adjusting high octane fuel map. Since open loop relies on the fuel maps to run. What coolant temps
Old Mar 23, 2017 | 10:44 PM
That explains everything.
You've probably got the IAT sensor in the usual wrong place.
Go back to MAF and you won''t have problems.
Old Mar 24, 2017 | 05:32 AM
ronaldo9's Avatar
There's a thread on here where people on speed density are having similar issues and adjusting certain temp scaling tables helped.
https://www.evolutionm.net/forums/ec...y-problem.html
Old Apr 19, 2017 | 07:36 PM
gixxer1621's Avatar
also check coolant temperature sensor
