Engine failure
Old May 5, 2017 | 02:29 PM
BakoEvo's Avatar
Thanks for all the feedback everyone I appreciate it! Now to bring her back to life and stronger and faster than before!
Old May 5, 2017 | 02:34 PM
Evo_Goodness's Avatar
You know i remember your other thread about a weird sound a couple of weeks ago could it of been the BS then ?
Old May 5, 2017 | 02:48 PM
kaj's Avatar
kaj
Good luck! I feel your pain.
I did a rebuild with forged parts. It went wrong when the oil pump balance shaft bolt came loose, resulting in rod knock.
I then threw all the OEM stuff back in. Fail. Thrust bearing was bad and the engine started eating it.
I gave up and ordered an OEM shortblock from Mitsubishi. No more playing around.
Car now runs like a champ. LOL.
Hang in there!
Old May 5, 2017 | 02:50 PM
Pal215's Avatar
If you plan to have a shortblock built by someone else, I highly recommend English Racing or TScomptuned.
Old May 5, 2017 | 03:16 PM
foxbat's Avatar
Balance shaft bearing failure is 100% a mechanical issue, there is no point in investigating the logs! When such failure occurs it's likely to be catastrophic as such. My advice for your future build, get an aftermarket BS bearing set, aftermarket BS belt, a brand new oil pump. ALWAYS keep an eye on your oil pressure, install an oil pressure gauge.
Noize
139
Jun 22, 2011 04:27 PM
drop24
Aug 23, 2010 10:12 AM
nj1266
84
Sep 15, 2009 07:20 PM
Derek888
Jun 23, 2005 12:06 PM
ThomBlazeEVO8
Mar 4, 2004 04:48 PM
