Injector duty near 100% up top
To be honest I'm not going to bother going that deep until I forge the engine etc. I'm peaking at 27ish psi, that'll do for stock internals I think
You shouldn't even be playing with the map on standard injectors.
Fix the fuel pressure.........revert to factory map....turn up the boost.
It'll run better than ever before.
Not sure I agree with that. I've heard evos run really rich from the factory to minimize the chance of knock which leaves plenty of room for more power to be made, and how can improving my afr be a bad thing anyway? You keep talking like you've seen my data logs or something. My map isn't even finished but I'm already seeing WOT afrs holding in the high 11s and creeping towards 11.5 at redline, no knock. I'm relatively new to this so don't want to argue with someone who seems to be more experienced, but telling me to switch back to factory map but upping the boost when ive changed the exhaust from manifold back, plus the intake seems like pretty bad advice. I've heard of x's leaning out and melting pistons just by changing the intake and not adjusting the map...
whtrice (Sep 16, 2017)
It ain't the 90's anymore buddy...
You've got no idea about correct IDC for a start....lol
When the IDC gets too high you'll hit fuel cut which just happens to be an inbuilt safety feature to prevent IDC being too high.
So long as you don't hit fuel cut, you've got IDC left to play with.
Right, new issue. Since I bought the car, in the colder weather ive had an intermittent miss at WOT in 5th and 6th. High rpm, always at about 5k. That is actually what convinced me to buy evoscan and start all this mapping stuff in the first place. Well it's starting to get colder here now and it done the miss for the first time in months, while i was logging. In 4th I'm hitting 1.8bar boost (27psi or so) until the turbo starts to run out of puff, afr moving from 12 to 11.5ish. In 6th it's hitting 1.9bar and is rich as hell. Hovering around 11. All of a sudden my injectors go to 0 for a split second and then it back to normal. I'll post a pic of my 4th gear pull and then the log for the 6th gear. At the moment my boost error correction is off, is that what I need to use (and boost desired engine load) to make 5th and 6th behave the same as 4th, because this Seems to only be a 5th and 6th gear issue for whatever reason?
thanks
4th gear
6th
thanks
4th gear
6th
Right, new issue. Since I bought the car, in the colder weather ive had an intermittent miss at WOT in 5th and 6th. High rpm, always at about 5k. That is actually what convinced me to buy evoscan and start all this mapping stuff in the first place. Well it's starting to get colder here now and it done the miss for the first time in months, while i was logging. In 4th I'm hitting 1.8bar boost (27psi or so) until the turbo starts to run out of puff, afr moving from 12 to 11.5ish. In 6th it's hitting 1.9bar and is rich as hell. Hovering around 11. All of a sudden my injectors go to 0 for a split second and then it back to normal. I'll post a pic of my 4th gear pull and then the log for the 6th gear. At the moment my boost error correction is off, is that what I need to use to make 5th and 6th behave the same as 4th, because this Seems to only be a 5th and 6th gear issue for whatever reason?
Also, what's up with your timing, are you really running 0* at 5k?
I noticed that with the timing but my other logs are ok. Must be a one off. I'll make sure though. funny you mention boost cut because it's set to 280 but almost the entire 6th gear log is over 280, delay set to 1000ms. Weird
A wise man once said
I've just set my desired load based on a 4th gear pull and returned the error correction to stock. Hopefully that keeps it all in check
Sounds like you have your boost control tables setup incorrectly. Also might be logging the wrong address.
Timing advance is still at 0. I would stop doing WOT pulls before you melt something from high EGT's.
Can you post your timing and boost control tables? Or better yet, share your ROM?
