Evo 8 ECU Communications port
Old Jan 3, 2018 | 12:05 AM
markseb44's Avatar
Hi all....please be gentle, I'm brand new.
Issue: I have a Evo 4 rally car, fitted with Evo 8 ECU, running Autronic SMC PNP board. I can not find EVO 4 OBD2 connector (not surprising, new ecu, new loom I gather). I did think I would find OBD2 connector somewhere, but can not?
What I wish to do is get data logging info from ECU, and hope to bluetooth it via plug in module to overlay data on camera.
My main question is.....is the little 3.5mm? [2.5mm] RS232 type plug on the ECU capable of passing data logging info to a OBD2 connection? I don't know much about it, and as simplistic as the audio type plug looks, apparently it can.
Any help appreciated
Old Jan 3, 2018 | 04:25 AM
jingalalahoe's Avatar
Make your own OBD2 connector!
Buy a OBD2 extension cable, cut the male end off.
Connect ECU Pin 56 to OBD Pin 1, ECU Pin 62 to OBD Pin 7, connect OBD Pins 4,5 to ground and OBD Pin 16 to +12V.
Old Jan 3, 2018 | 08:24 PM
markseb44's Avatar
Hey,
Thanks for the info. After many hours of trying to get the correct wiring diagram, you are spot on the money!
Thanks very much for your help, it has put me on the right track. It may be easier to use the audio jack to serial...and then an adapter to bluetooth, only because of the relative inaccesability of the wiring loom.
But at least I have options and a clear path ahead.
Cheers
Mark
TheReaper
Apr 20, 2018 09:18 AM
RallySport9
Sep 9, 2013 11:12 AM
csiplon
Lancer Troubleshooting
Oct 23, 2007 02:18 PM
1QWKEVO
May 28, 2003 09:26 PM
