AutoLogger. Another utec logging software.
Old Apr 10, 2004 | 06:22 AM
LiquidForce's Avatar
This code was originally written for the WRX version of the UTEC and I am curious to see if it would work on the Evo version.
The app has automatic logging features based on TPS or RPM. It has a digiatl dash and can log the data from the UTECs dashboard screen as well as any of the other logs. It also has an active chart which gives a real time plot of the log. You can turn on and off the data elements that you want to view on the graph.
It will also play back the log files.
There is also a feature to automatically log when there is an knock event.
A road dyno feature is also in the software but it is not complete. I still need to finish the smoothing. If this works on the Evo then I will very motivated to get it finished.
Another feature is the integration with another piece of software called DataLogLab. Its mentioned in another thread
https://www.evolutionm.net/forums/sh...threadid=75076
the link is
http://www.irie-systems.com/autologger/Versions.asp
edit I forgot to add that on the dashboard view the peek values are stored. You can then view what all the other variables were when you hit that peek value.
The app is written in Delphi so there is no need for a set up. Its all right there in one true executable file.
evo4mad
May 5, 2015 06:22 PM
MalibuJack
Dec 3, 2007 07:12 AM
MalibuJack
Mar 24, 2007 12:45 PM
DataLogLab
12
Apr 15, 2004 01:16 PM
genimport
Feb 26, 2004 08:19 PM
