Failed SMOG in CA *PLEASE HELP*
Old Jun 27, 2019 | 11:51 AM
  #106
Fox_IX's Avatar
I agree with the spirit of the laws, but I have serious issues with the implementation.
I think the reason it can't be as simple as what comes out the tail pipe is that the smog tests we go through are not comprehensive. The testing the OEM's have to go through is intense, and that recipe or configuration if you will is what gets certified. The smog tests we take these days are relying almost completely on the self reporting capability of the car and its ability to report deviations from that configuration.
There is a mechanism to get a modification approved, but its a huge expense and a PITA to go through. That's why there are so few parts with a C.A.R.B. EO exemption. I think that whole system is a racket and needs reform.
On the broader social topic, the world is just going to keep getting hotter unless we can right the ship. Things aren't look too good though.
I love California. We don't care what your tailpipe puts out as long as the parts manufacturers threw us about $20k for testing. My car currently produces lower CO and NOx emissions than stock, yet it's technically illegal in California because I used generic parts.
Old Jul 2, 2019 | 09:21 AM
  #107
evostanman's Avatar
so before I install all of my go fast parts again AND my newly purchased ID 2000 injectors and wally 450 pump, this question popped in my head....
Is my car flagged in the "system" even though I passed the ref inspection? I'm debating on installing everything again or keeping it stock.... I should've thought of this prior to purchasing my injectors and pump.
Old Jul 2, 2019 | 12:25 PM
  #108
zeRep85RA's Avatar
Ive wondered this too...
Like for medical marijuana cards....this magical list.
z
e
R
e
p
Old Jul 3, 2019 | 11:32 PM
  #109
EV09AWD's Avatar
5 Year Member
Please help, i have the same problem.
Data check failed.. sent to REF, Data check failed again.
Working with a 2006 USDM EVO 9. ROM 88590015 (please let me know if this is the wrong rom)
I got the car that was tuned and many monitors turned off.
I downloaded a factory 88590015 rom, flashed it onto my car, and only changed the immobilzer code to start the car.
Then I installed all factory parts, let all the monitors go through course to "READY"
Took it to ref, it passed everything except still "DATA CHECK FAIL"
The only thing the ref told me was that the software "Still didn't match the car" ..... not sure what I need to do here, Mitsubishi service doesn't deal with this and suggested I buy a brand new ECM....
Please helpppppp.
Old Jul 3, 2019 | 11:34 PM
  #110
Fox_IX's Avatar
Please helpppppp.
I have the same car, if you wanna post your rom I can compare it to mine which recently passed even with the force monitor patch. No data check fail yet for me thankfully.
Old Jul 4, 2019 | 01:15 AM
  #111
EV09AWD's Avatar
5 Year Member
Originally Posted by Pal215
Agreed,
We can treat it just like the immobilizer code. Downloaded from the original base 9 rom and copy/paste it in
How do I do this? I know how to read, and write roms, and explore its contents. about it...
Where do i view it and change it on?
Old Jul 4, 2019 | 01:46 AM
  #112
Fox_IX's Avatar
Do you have an OpenPort? How did you flash the ROM previously?
OpenPort and ECUFlash will be able to read/flash the ECU and is definitely something to invest in if you plan on having your evo for a long time.
Old Jul 4, 2019 | 01:51 AM
  #113
EV09AWD's Avatar
5 Year Member
Thank you, Here is the Rom I currently have flashed and failed DATA CHECK on my car.
I downloaded from the ROM suppository. Added my immobilizer code, and for some dumb reason I lowered the REV limit and stationary rev limit...( i hope that didn't cause my problems)
Could you please look over it, is it possible someone add my VIN to this ROM or CAL ID or whatever I need to do....
Thank you community
***(UPDATE 1-2020)***
I have passed referee with flying colors. I wanted to help others in the future by updating this post. By changing only the rev limit and stationary rev limit, this caused my CVN numbers to change and not match factory numbers, which caused data to mis-match and FAIL. I put these numbers back to factory rev limts, and only changed my immobilizer code to start the car, then I passed the data check.
File Type: bin
Old Jul 4, 2019 | 01:52 AM
  #114
EV09AWD's Avatar
5 Year Member
Yes I did invest into a Tactrix cable, and Have ECUFlash / EVOScan. Anything else I should have that might help?
Old Jul 4, 2019 | 10:10 AM
  #115
Biggiesacks's Avatar
If your at the ref the ROM has to be completely stock, a single bit difference will alter the checksum and fail.
Old Jul 10, 2019 | 08:28 AM
  #116
evostanman's Avatar
z
e
R
e
p
Does anyone have any input on this? I would really like to know before installing cams again.
I really really don't want to ask on bookface.... too many tards over there.
Old Jul 10, 2019 | 10:32 AM
  #117
EV09AWD's Avatar
5 Year Member
Hey I think you can goto the BAR smog vehicle test history page, and check your car. It will tell you if your vehicle will need to goto a STAR smog only shops (enhanced smog).
I'm guessing you will be required for STAR testing for future smogs...
https://bar.ca.gov/pubwebquery/Vehicle/PubTstQry.aspx
Old Jul 10, 2019 | 10:45 AM
  #118
lv05evo's Avatar
I have to smog my car at STAR stations and I never been flagged. I forgot and went to a smog place that does repairs too and they said I have to go to STAR stations.
Old Jul 10, 2019 | 03:28 PM
  #119
kaj's Avatar
kaj
Kalifornia has me going to STAR smog every other year. I assumed that was the same for everyone.
Old Jul 10, 2019 | 03:54 PM
  #120
yep same here STAR....i guess someone let the cat out of the bag that Evo's like to be modded. I've never been sited for emissions related stuff.
