Wanted:965 evo rom map sensor voltage to load table for Tephramodv7 SD
Old Mar 4, 2020 | 09:53 PM
herrhorace's Avatar
Hi guys,
I am currently tuning my 4G69 to run with an Evo ECU. I got it started after quite some modification to the cam and crank triggers and with serious modifications of the wireloom. I also have the MIVEC running off the IC spray circuit.
I am however looking to use a different map sensor than those listed in the Tephrav7 SD Map VE and Calibration table, hence I would like to know where I can find working voltage XML tables for the map sensor so that I can properly scale the one I am using.
I tried a few based on the 941 roms but they show messed up values in the thousands.
Igor_Predator
May 7, 2017 01:13 AM
rxtec
Mar 14, 2016 09:03 AM
rxtec
Dec 14, 2015 06:49 PM
X.0 EDITION
Sep 23, 2014 11:48 AM
Pimp Excape
Aug 13, 2013 12:42 AM
