Revisiting EvoScan
Revisiting EvoScan
So.. went to open up EvoScan to help out a fellow Evo owner and I got an error. Went to website and re-DL'ed EvoScan v2.9.0100. Now, when I open it, I notice it's different. I.E. there is no longer IACV AC ON and IACV AC OFF.
Are there EvoScan definitions that we install, like we do with EcuFlash? It's been so long, I honestly can't remember. Thanks, in advance!
Yep the XML definition file is C:\Users\YourName\Documents\EvoScan v2.9\DataSettings\Mitsubishi MUTII EFI.xml. If you updated there might be an old version of the XML settings file with what you were used to. You edit the settings using Logging > Edit Data Item list
**update. No older versions saved. Boo. I changed my search over to trying to find the definitions that I need. It's been years and the information seems to be buried pretty deep. Wish me luck!
I may try downloading an older version of evoscan.
prostcj
Jul 24, 2008 06:32 AM
