dual map flex fuel and speed density
Old Jun 1, 2021 | 11:12 AM
Airwreck's Avatar
so i have a full flex fuel set up and a speed density kit. i am wondering if it'll be safe to drive up to get tuned? the dyno tuner lives 30 mins away. I am thinking that i cant because the car is tuned for maf that it wont even turn on even with the new speed density kit.
Old Jun 1, 2021 | 12:11 PM
Ive had to make that 30 min drive a couple of times myself to see the tuner on non scaled injectors. The general rule of thumb is stay out of any manifold pressure & vacuum your way in.
Your situation is a bit different as your going in on a new SD setup. I guess you should try to start it & see if it runs? If not, cheap insurance on flat bedding the EvO there!
Old Jun 3, 2021 | 10:36 PM
Airwreck's Avatar
ig that is the best way to find out. Thx for the tip !
Old Jun 4, 2021 | 08:21 AM
Evo9_Dubai's Avatar
Do you have a wideband gauge? If so, how does it idle? Lean or rich? If your cruising AFR is within normal range, you can drive it no problem. If it's pegged rich or lean, then obviously not,
MinusPrevious
Aug 21, 2013 08:18 PM
AWD Motorsports
Evo 'For Sale' Services
52
May 15, 2013 11:01 AM
evoxsi
Aug 18, 2012 03:39 PM
dsevo
AEM EMS
15
Jul 26, 2006 05:25 AM
Juiced
Feb 28, 2006 07:12 PM
