evoscan
Old Jul 31, 2022 | 10:39 PM
Stev-o-evo's Avatar
evoscan
hey guys im new to all this im trying to figure out with cable I need to get and witch site to download evoscan from I was getting the evoscan page and now Im getting a different page have no clue why this is I just got my evo 8 2005 and went to get the car tested with emissions and while waiting in line the car started over heating and the check Engine light came on the car stoped over heating I drove it back home its not overheating but the light is still on so I wanted to check it if anyone can help I would really appreciate it thanks guys.
Old Aug 1, 2022 | 05:50 AM
Biggiesacks's Avatar
https://evoscan.com/ recently updated their page. I would recommend the the tactrix openport 2.0.
Sucks about the overheating and CEL. Evoscan will certainly allow you to read the code and test out hardware like the radiator cooling fans.
Old Aug 1, 2022 | 07:38 AM
Stev-o-evo's Avatar
awesome man thank you so much!! I was getting worried like where didi that site go? lol thanks a bunch man and about the cable what is different compared to the 1.3u cuz I wont ever buy a evo x and im seeing the that tractrix 2.0 is better for the x ? and yeah it really sucks about the overheating 🥵 but at least it went away I drove it from California with no problem the 3rd day waiting in like for a long idle she did not like that,.
Old Aug 1, 2022 | 07:45 AM
The 2.0 can do stand alone logging to an SD card, and it can also take an aux signal from a wideband. So you can have a pretty nice logging setup with no laptop in the car. The only other thing is you will have to jump through a hoop or two to be able to flash the car with the 1.3U. AFAIK the newer versions of ecuflash wont work with non-tactrix cables. So if you want to tune you will have to read/write with evoscan and edit with ecuflash. There is also the possibility of using an older version of ecuflash that doesn't do the hardware checking.
IMO the stand alone logging is well worth it, but if you don't see yourself ever using it, and bouncing between software doesn't phase you, then there is nothing wrong with the 1.3U. I've got both and the logging speed is basically the same.
Old Aug 1, 2022 | 10:05 PM
Stev-o-evo's Avatar
ok cool thanks man yeah im sure the data logging is gonna be super important so now after hearing this im leaning towards the 2.0 remember man im a noob to all this I've been wanting an evo for years finally got one so im a learning now.thank you so much for the help man.
andrewRA
Nov 16, 2020 05:19 AM
Red Dragon
Aug 12, 2009 03:52 AM
dsm25psi
May 4, 2008 08:53 AM
freddiet
Jul 7, 2006 08:35 AM
