Tuning help?
Tuning help?
Hello tuning wizards. I FINALLY got my evo running after 2.5 years dead from a spin bearing. I upgraded the fuel pump and injectors incase I got the itch to go E85 since I relocated to Texas and can get it now. I jumped in the ROM to change the injector scaling since I needed to and figured I would look at the fuel and timing maps.
I know I desperately need help with tuning my car now because I have no idea who tuned this before but this does not look anything like any map I’ve seen before.
im definitely willing to learn and figured I could make a few changes if needed but I feel like 10+ degree timing changes cell to cell is wrong.
help?
help?
Ok.
So I have decided to start from scratch because this tune looks like a blown motor waiting to happen - again.
Where I am going to start:
As a reference for mods:
BBK Full turbo
XSPower O2 housting & downpipe with Apexi 3" exhaust
Kelford 272 cams
ETS UICP, LICP, intake and IC
FIC 1200s, Radium fuel rail, FPD, FPR and AEM 320lph pump
OMNI 4-bar
GM 3-port.
I may be missing some things.
I have already set manual fuel pressure to 43PSI w/o the reference and it runs where I would expect at idle with the reference.
I have a full DEFI gauge set to visually check boost, oil pressure, fuel pressure and exhaust temps just in case and an AEM wideband set up for logging.
I am going to use Tephra V7.
I have set the MAP scaling to align with Mr.Fred's post on setup and scaling:
0.51 25
0.90 49
1.29 70
1.68 96
2.07 120
2.46 144
2.85 170
3.24 195
3.63 255
I have also updated to relating MAP tables per Mr.Fred.
I am going to scale the injectors here as a start and tune based on fuel trims:
1008
latency values:
<!--td {border: 1px solid #cccccc;}br {mso-data-placement:same-cell;}--> 4.69 4.08
7.03 3.07
9.38 2.06
11.72 1.46
14.06 1.13
16.41 0.94
18.68 0.72
With the Kelfords I am going to adjust timing at idle to +7 but leave the rest near factory spec to begin.
Looking for some other initial guidance. I *think* that will let the car idle ok and I can work out drivability from there. I do have questions on scaling the MAF since I have changed the full intake system up to the throttle body and don't quite know where to start on the WGDC maps.
A lot of the existing tune has flat numbers for all values and weird steps in values cell to cell that tell me I am going to end up changing everything, so ANY guidance would be much appreciated.
Thank you all in advance!
BBK Full turbo
Kelford 272 cams
OMNI 4-bar
GM 3-port.
0.51 25
0.90 49
1.29 70
1.68 96
2.07 120
2.46 144
2.85 170
3.24 195
3.63 255
1008
latency values:
7.03 3.07
9.38 2.06
11.72 1.46
14.06 1.13
16.41 0.94
18.68 0.72
MicRX (Sep 11, 2023)
Ok everyone, I could use some help now and I know there is something that I am missing so please enlighten me.
Below are my ignition and fuel maps. I have also posted my Injector scaling and latency tables and a copy of my 2 most recent logs.
I am still running this car what I feel is conservatively on fuel though timing is I think close to the landing point. My concern is battling this part-throttle knock. I have left my fuel so rich because this is a persistent issue however retarding the timing is not showing an improvement. Where I get concerned is that the knock consistently comes in between 2500-4k in the 80-120 load range. I am picking up some knock elsewhere and it appears that I am getting some significant shift knock when I go WOT and slam gears (I have read this is a problem) though I will say I tend to drive like a grandma so this is more for logging purposes to get the tune right. I daily this Evo, I don't race it.
What am I missing here? What am I doing wrong?
For the injector scaling, my fuel trims continue to show as +5 or higher and it seems weird that I would be putting the scaling so low for 1200cc injectors.
Please help.
Thank you
Please help.
Thank you
Octane Blue
Mar 15, 2012 09:30 PM
