Evo will only start once after flashing
Old Jan 7, 2024 | 03:51 PM
Ajsaboss's Avatar
I've got an Evo 9, trying to flash tephra V-7 non SD 88590715 (stock rom was 8859016) using ecuflash. I believe I have changed all required tables, but when I flash the ECU it will start as many times as I try (start, turn off, key out, key in, repeat) until I open a door or lock the car, then the car will not start and will just crank. This happens with and without the immobilizer disabled. Car is currently stock besides an omni 3bar map sensor. When the car starts after flashing flash it is a fully working tune and I was able to log data. Just each time the car is parked basically it needs to be flashed. Stock rom seems to not suffer from this issue and will fire regardless of this circumstance. Can anyone help me out?
codean
Feb 13, 2016 08:48 PM
Creatre
May 11, 2015 05:09 PM
Jorge T
Feb 8, 2010 04:50 PM
jdmevo123
Jan 6, 2010 05:05 PM
djd24
Sep 24, 2006 09:46 AM
