A reputable tuner is always recommeneded. Florida has AG autosports, Slowpoke tuning and Mtuned. You get what you pay for .
Cruise AFR should be around 14-15 AFR if it has small cams.
Getting into boost should be 13.-12.5 until 15psi quickly tapering to 11.2-11.5. I wouldn't suggest 11.8-12.0+ on pump gas or ethanol. Fuel cools the cylinder. Anything in the 10's is a little too rich .
