Autronic/ Air Condition
Old Jun 20, 2004 | 05:51 AM
EVO440's Avatar
Does the autronic ecu work the air condition because my evo 4 has this ecu and my air condition doesn't work when i asked around everybody told me that maybe the ecu does not work it is this true
Old Jun 21, 2004 | 08:03 AM
sethor's Avatar
with the PnP yes it will work
with the wire in models i dont think you can't but best to check on the autronics forum www.autronic.com
Old Jun 22, 2004 | 07:02 AM
beerstream's Avatar
The EVO8 board shouldn't have a problem with the air conditioning. However, there are settings that can be made with the software. You may want to plug in and check your settings. I haven't heard about Mitsu changing any wiring on the ECU for 04, but it's possible. You may want to do a search for the ECU wiring diagram and compare it to your 04's harness (I haven't looked at an 04 harness yet).
Old Jun 23, 2004 | 05:18 AM
robvii's Avatar
I have autronic on my 7 and it does work the AC. however you need to link the compressor to a relay output on the board to make this happen...contact MArk shead at MAD on the lancerregister...he will help
Old Apr 20, 2005 | 08:02 PM
RAllen's Avatar
Also note that the on board relays are just in fact negative triggers which must be wired to external relays.
Old Apr 21, 2005 | 01:46 PM
Curt@MrLed's Avatar
Former Vendor
i have it on my 8 and no probs..well just the lack of having the idle stepper motor work..
thee stig
Oct 12, 2011 08:41 AM
summercloud
May 7, 2011 02:04 AM
Bimmubishi
11
Oct 13, 2008 08:03 AM
HuskerEVO
Jun 25, 2005 08:54 PM
evosevengsr
Jul 31, 2004 10:02 AM
