MAP Sensor install?
Old Dec 6, 2004 | 07:38 PM
MalibuJack's Avatar
There ya go..
Old Dec 6, 2004 | 07:56 PM
VTECH8TR's Avatar
Originally Posted by MalibuJack
There ya go..
Malibu,
Mine works perfect now .
Old Dec 6, 2004 | 10:32 PM
negativeB's Avatar
thanks guys. btw, on the website, they don't have that sensor anymore. they changed it to a different one. does it matter? will the new one work?
Old Dec 7, 2004 | 04:05 AM
VTECH8TR's Avatar
Did you read what i posted. I gave you the part #'s i just ordered a week ago.
Old Dec 7, 2004 | 04:20 AM
negativeB's Avatar
Yes I read it. This is what is on the website.
"The old 16040749 part number has changed to this 2nd design and will require using a new connector 15305891 when replacing the first design sensor with the new 2nd design map sensor" That isn't the same part number you posted.
So what else do I need to convert to MAP sensor?
Old Dec 7, 2004 | 04:24 AM
MalibuJack's Avatar
This is not a CONVERSION to a map sensor, this only adds the ability to run closed loop boost and show boost pressures in your logs.
You can also use MAP as a load reference in your maps..
Just be aware this is NOT a speed density conversion..
With that said, you'll need a 4 pin square molex connector and a set of pins (its the same power connector on an ATX+12 power supply if you have a trashed one laying around)
You can get that part from www.mouser.com if you need the part number, there's a thread on that in this forum, or look in the UTEC docs towards the end of the doc there's a section that shows the part #'s for the pins and connectors you need.
Old Dec 7, 2004 | 04:30 AM
negativeB's Avatar
thanks for clarifying.
Old Dec 7, 2004 | 04:35 AM
MalibuJack's Avatar
Yeah, TurboXS is working dilegently to get us a speed density conversion and some other cool stuff soon.. So having that map sensor is a worthwhile investment in time and effort.
Old Dec 7, 2004 | 05:07 AM
VTECH8TR's Avatar
Malibu,
How does the closed loop boost work out for you. I was going to activate this the other night but seen some high IDC's. I am putting in new injectors in today and trying it again tonight.
Old Dec 7, 2004 | 05:19 AM
MalibuJack's Avatar
It works, it spikes a little but basically it sticks to your target pretty well.. If you set it to not spike as much, you end up hurting the boost response so its a bit of a compromise.. The one GREAT thing about it is when the weather changes, your boost doesn't go up or down by 1psi or more (Assuming the solenoid and ABC are adjusted so there's enough range of adjustment) the GM solenoid and closed loop boost works best, but sucks if you still use stock mode occasionally (I do occasionally to collect timing data for different weather, unfortunately I now get fuel cut in passthrough so I don't do it anymore)
Old Dec 7, 2004 | 10:13 AM
Imprezd's Avatar
I haven't had a minute to read the whole post over again, but I wanted to note to you guys that we do have TXS Map sensors available now. Actually Malibu it's the same one that works with our DTEC. They are all calibrated before they leave our manufacturing facility and they also plug directly into the side of your EVO8 UTEC without the mad hunt for molex connectors. Using the MAP sensor as a load reference makes tuning a ton easier, you’ll have a more gradual sweet through load sites rather than the large jumps the map is notorious for doing. You can also assign a MAP based fuel cut instead of using the MAF frequency fuel cut for overboost conditions, I don’t know about you but it’s easier for me to assign a 22psi fuel cut rather than 1900hz. As probably most of this post refers to it allows you to use closed loop boost control which help you have very consistent boost levels in about all whether condition.
Retail - $119.00
Thanks,
Jermaine~
www.turboxs.com
Old Dec 7, 2004 | 10:31 AM
VTECH8TR's Avatar
GO with the TXS setup one, i went through hell to get my parts for mine. I drove to 3 radioschacks,waited for parts,etc..
Old Sep 13, 2007 | 12:33 PM
1QYK9's Avatar
I have both an Evo and a S2000. On my S2000 the OEM map sensor is located on top of the intake manifold. I purchased an AEM 3.5bar map sensor and had it wired into the OEM map sensor wiring harness. I can switch back and forth between the two map sensors at any given point if so desired. The AEM map sensor has a threaded fitting on it, and I had a special piece fabricated which allowed the AEM map sensor to be screwed into it, and then it is attached to the intake manifold. Here are some pics:
I am new to the Evo scene and am trying to learn the differences between mod'n the two cars. Can I not do the same sort of setup on the Evo as I have on my S2000?
Enyth
Apr 12, 2016 09:06 PM
sean-EVO4-nz
Mar 3, 2016 04:23 PM
jameswwt
Aug 1, 2015 03:32 AM
Mr. Stock
Aug 30, 2005 02:27 AM
GTVEVO
17
Oct 5, 2004 07:20 AM
