BR580, round 2
Old Jul 18, 2004 | 05:13 PM
justrick's Avatar
fuel
hey jerstan...nice numbers very nice, where do you have you max maf frequency set to. i had mine mapped really nice only to discover that i didnt raise the max maf value, but i dont know if i should put it at 26, which is what my turbo makes at 19.5 psi or 28 which is the 24 psi reading, but im going to lose allmy fuel settings and start all over again, would you be able to supply me with your fuel map. i would really appreciate it, i cant get to a dyno, and road tuning is way time consuming..i dont want to start all over again...
also does your engine load up between shifts during a run,, mine does just wondering how you fixed....
regards rick
Old Jul 18, 2004 | 05:21 PM
MalibuJack's Avatar
Damn, 2800hz? I think your slowly approaching the max maf value that the stock MAF sensor will support..
If your MAF frequency is way lower than what your hitting under boost, then you should raise it to allow you to give yourself part throttle high boost open loop control..
Old Jul 18, 2004 | 05:33 PM
93h22cvc's Avatar
that noise is compressor surge. common on large turbo's without surge ports
Old Jul 18, 2004 | 08:46 PM
jerastan's Avatar
Originally Posted by MalibuJack
Wait, your using a TXS Manual boost controller? It has a combination of restrictor and bleed valve to control boost.. is the bleed valve closed fully while your making your rough boost setting adjustments to the ballvalve? If the bleed valve is not fully closed you will effect the ramp of boost since it affects the buildup of pressure to the wastegate actuator. PLUS it will make a loud hissing noise if the allen set screw is too loose or missing...
Yeah, we didn't mess w/ the bleeder until we had made the main adjustment.
Old Jul 18, 2004 | 08:47 PM
jerastan's Avatar
yep, that's what it was. the Tial bov is so tight that the air is not releasing fully. i'll have to order the lighter spring from Tial.
Old Jul 18, 2004 | 08:48 PM
jerastan's Avatar
regards rick
let me se what i can do. pm me if you get a chance.
Old Jul 19, 2004 | 09:01 AM
Imprezd's Avatar
Nice Dyno numbers, seems as though you are having some boost issues. Also do you notice you are making peak power at low boost. Their is more left in that setup it has to be or i am just plain reading the plots wrong. Good numbers nontheless.
Jermaine@turboxs.com
www.turboxs.com
Old Jul 19, 2004 | 10:37 AM
jerastan's Avatar
www.turboxs.com
Yeah, we've got some boost issues. Not sure what's going on yet. Can't seem to find any leaks. There's still a lot of power to be made here, that's for sure.
Old Jul 19, 2004 | 10:46 AM
ez76's Avatar
Have you experimented with advancing the intake cam and retarding the exhaust cam?
Old Jul 19, 2004 | 10:55 AM
jerastan's Avatar
yeah, not very good results. we were only trying a few degrees though the -3 intake/-1 exhaust proved to be the best for us so far.
Old Jul 19, 2004 | 02:35 PM
MalibuJack's Avatar
It seems that the best idle comes from the -3/-1 or -4/-1 combos... time will tell what sort of upper RPM effect this will have.. Definitely been an interesting journey eh?
Old Jul 20, 2004 | 10:34 AM
MalibuJack's Avatar
That was an interesting conversation we had last night.. Can you send me a photo of the upper intercooler pipe I'm curious about something on it.
Old Jul 20, 2004 | 10:48 AM
jerastan's Avatar
Sure was. I've been thinking alot about that second bov. Here you go...
Old Jul 20, 2004 | 11:26 AM
erioshi's Avatar
I know you've tried other cam settings, but have you looked at 0/0 or +1/+1? I think many of the euro guys are finding that advancing their cams (JUN and Piper - which are loosly based on JUNs) really helps the low end. My guess is that the offsets from stock are different than for a set of HKS cams.
I should have my car back later this week and will by doing some logging with my Pipers. I'm running an XEDE right now, but depending on how long it takes to get the tuning features I need, you may see me switch.
Good luck with getting things sorted.
Old Jul 20, 2004 | 12:02 PM
jerastan's Avatar
I ran w/ those settings and had no luck. I actually just sold the kit. I just installed a new kit, and lets just say that I have not even tuned for it yet and the spool up starts way low and hits hard!! I'll post some new numbers very soon.
Jeremy
