Gruppe-S Engineering - California [Visit Site]
Apex'i S-AFC II back in stock!!!
Old Apr 17, 2004 | 03:16 PM
Gruppe-S's Avatar
Hello Guys,
Just got a shipment of Apex'i S-AFC II in Black and Silver.
The third-generation S-AFC is a fuel computer that adjusts fuel/air ratio by modifying the air-flow meter / MAP sensor signal. The S-AFC features a user-definable, twelve-point, adjustable fuel curve that can be set in 250 RPM increments. The range of fuel adjustment is +/- 50% at each of the user-defined setting points. On hot-wire vehicles, the Deceleration Air Flow Correction function is capable of curing the erratic idle and stall problems associated with open-atmosphere blow-off valves on hot-wire air-flow meter systems. The S-AFC is capable of monitoring and replaying the following data channels in Numerical, Analog Meter and Graph displays: Intake Manifold Vacuum/Boost Pressure, Air Flow Capacity, Intake Manifold Pressure, Karmann Frequency, Engine RPM, Throttle Position, and Air Flow Correction %. New features also include knock detection, switchable dual maps, and password protection.
Price is $324 shipped!!!
Please give us a call for questions and orders!
Thanks
Cal
gruppe-s
510-498-8400
