HKS GTII 7460R Turbo Kit - Evolution 8 & 9 in Stock - Cams & Springs - $1995 Shipped
Ask and you shall receive!! Import DPS just stocked up on the remaining HKS GTII Sport Turbo Kits for the Mitsubishi Evolution 8 and 9. Limited amounts are available for each model and these will sell very fast. We have the kits that come with the HKS Camshafts and HKS Springs. Any questions, please post up and we will gladly assist you.
Check out the HKS Press Release on this Item - http://www.hksusa.com/info/?id=3818
HKS USA, Inc., the premier manufacturer and supplier of premium automotive performance systems, proudly introduces the GTII 7460R (reverse rotation) turbine; an original HKS designed and in-house manufactured bolt-on, stock replacement turbocharger for the Mitsubishi Evolution IV-IX.
As the first of the new HKS turbocharger line, the GTII 7460R incorporates a reverse rotation turbine design that provides the benefit of a bolt-on application, stock replacement upgrade turbocharger for the Mitsubishi Evolution IV-IX.
The special cast turbine and compressor housings of the HKS GTII 7460R allows it to be a true bolt-on upgrade for the Mitsubishi Evolution IV-IX by utilizing the OEM exhaust manifold. The HKS GTII 7460R is also a twin scroll, reverse rotation turbocharger. This design allows for a shorter and straighter exhaust path to the turbine wheel, delivering the benefits of less restriction and increased boost response while allowing full spool and stable boost pressure throughout the RPM range. Intake and exhaust port designs optimize the flow area to allow an increase in air-flow capacity while the ball bearing center housing rotating assembly (CHRA) improves low-speed response and quicker boost pressure ramp up times Use of premium materials include inconel® for the turbine wheel because of inconel’s resistance to oxidation and its ability to maintain its structural integrity in high temperature atmospheres. Special heat resistant cast material increases the reliability and durability of the turbine housing.
Pictures of the Evolution 8 Kit we just got opened up for a local customer.
*** HKS GTII Sport Turbo Kits - Just $1995 Shipped ***
Part #11004-AM001N - Evolution 8 - 3 in Stock - Includes Cams and Springs
Click Here to Order - http://importdpsonline.com/hks/hks_g.../i-396142.aspx
Part #11004-AM001K - Evolution 9 - 2 in Stock - Includes Cams and Springs
Click Here to Order - http://importdpsonline.com/hks/hks_g.../i-396143.aspx
Please use the links in the sale thread to order or just call us at 215-227-6000/866-703-8794. We accept Visa, Mastercard, American Express and Discover Cards. Cash Local Pickups are also welcome.
Thanks
Rick
Import DPS
http://www.youtube.com/nyce1s#p/u/3/qY2p6VK1VAQ
Check it out Crew!! Thanks as always for all your support.
Rick
Import DPS
Rick
Import DPS
