Peacing together turbo: t3 ot t28?
they can both work to an extent, from the more experienced guys they are all going to tell you this... it all depends on what you PLAN to do with the turbo setup. granted the t28 can be plenty spool for most PSI, i personally think the T3 would be better for an application of higher boost. read up on them, each turbo spools at different rpms and reaches its peak at different rpms. again, it all depends on where you want to go with the setup. moderate, aggressive, no tune, full tune. lotta choices.
I agree with Airquez. The T3, especially the super 60 trim will be more efficient at producing the same amount of spool with less effort than the T28 and it can produce more maximum boost than the T28. It may lag a bit more but I doubt it will be very noticeable. I'll let you know once my turbo kit is done.
WTB[West]: T4 turbo kit
EVO 4 life
Nov 15, 2016 07:11 PM
