Kinugawa Turbo on Evo 8
I've checked Kinugawa's website and they only list Turbos for Evo 9. Don't they fit Evo 8's?? Why are they only listed for Evo 9??
I do have an Evo 9 Turbo on my 8. I want to upgrade the turbo but don't want to spend too much like $2000ish. Do you guys think a 20g or a 25g turbo is a good choice for me??
Is there like an Evo 8 install kit for these??
https://www.evolutionm.net/forums/ev...bo-thread.html
You didnt check their website out too well
http://shopping.kinugawaturbo.com/tu...mount-1-2.aspx
so we come back to the other question
Here are the other stuff I purchased but didn't install yet
GSC S2 Cams
HKS Cam Gears
MAP Beehive Springs
MAP Ultimate Duty Headstuds
ITM Revised Lifters
MAP High Performance Valves
Walbro Fuel Pump
FIC 1050cc Injectors
AEM EMS
MAP 02 Housing with External WG Dump
3'' Exhaust
GSC S2 Cams
HKS Cam Gears
MAP Beehive Springs
ITM Revised Lifters
Walbro Fuel Pump
AEM EMS
3'' Exhaust
or am I blind??
http://shopping.kinugawaturbo.com/ki...0ps-4-3-1.aspx
when I choose the 25g on kinugawa website, it won't let me select any options such as 11.5 or billet wheel
or am I blind??
or am I blind??
They're separate options http://shopping.kinugawaturbo.com/tu...hks3037-1.aspx
but i just realized the 11.5 wont work with the 25g I think....
The 9 is the only turbo with the compressor cover large enough to fit upgraded wheels of those sizes. You can put a nine turbo on eight so they are compatible, just don't use your evo eight turbo outlet pipe or waste gate actuator
http://shop.midwestturboconnection.c...illet-TD05.htm
Jerry i think what he means is that you can't upgrade the evo 8 turbo's because the kits usually come with anti surge housings too.
I've only found one company on ebay that sells 20G anti surge evo 8 housings.
I actually bought a billet 20G wheel with anti surge housing to find it didn't work on my evo 5 turbo
So i scored an evo 9 core housing off a friend and i'll put that together.
I agree that the Evo 8 turbo/compressor upgrade market is lacking, i tried convincing the company that made the 20G wheel i bought to make an evo 8 anti surge housing.
I still haven't had a chance to test it yet, work comes first.
Cheers, Mike
So i scored an evo 9 core housing off a friend and i'll put that together.I agree that the Evo 8 turbo/compressor upgrade market is lacking, i tried convincing the company that made the 20G wheel i bought to make an evo 8 anti surge housing.
Cheers, Mike
partsman t
171
Oct 21, 2017 03:15 PM
EvoIX89
Oct 8, 2016 08:44 PM
