EVO exhuast gaskets fit?
Hey does anyone know if the stock EVO exhaust gaskets will fit the regular Lancers? I'm looking to get some beefed up ones down line from the turbo where my test pipe is. (Where second cat. goes)
Just hit any parts store. Take a stock one and show them. They'll probably offer a beefier one. Just gotta match up the size, etc.
I know that I got some nice ones with my Buschur exhaust parts.
I actually went to several parts stores and they didn't have any 2 bolt or 3 bolt gaskets when I kept blowing the gasket between the downpipe and testpipe. I was gonna use an evo gasket also because I think their stock piping is 2.5" (is that right?).
Well, come to think of it, the cat. gaskets should be the same as the dowpipe so I had posted somewhere else that I found that SCE makes two-hole copper collector gaskets. You have to ream the bolt holes out a little bit, but mine has worked perfectly.
RRE metal/composite exhaust gaskets (strong)
http://www.roadraceengineering.com/f...andgaskets.htm
stock gaskets
http://www.drivewire.com/mitsubishiparts.html
stock gaskets
Don't know if you guys noticed, but I ordered some OEM gaskets for the second cat area, and they are now all silver coated with a thicker looking metal ring on the inner diamter of the circle. Old ones looked brownish with a flatter metal ring.
