TSI Non-IC Kit
TSI Non-IC Kit
After much debate and consideration I decided to go with a NON-IC TSI turbo kit. I expect it in a few days and was wondering if anyone had any tips or even a heads up on the install. Also, this kit comes with no fuel management, is it necessary for me to add on to this, just for peace of mind? I will be getting gauges as well (Boost, EGT, and AFR). Any help is appreciated! Thanks!
(EDIT)
Here is the Kit I ordered https://www.prostreetonline.com/buy/...o_kits/ml2501/ .... I actually had enough for the RRM stage 1, but after much thought decided I'd rather go with the lesser kit and see how much I can get from it by adding to it little by little over the next year and use the money I have now towards other things. As Boe told me once.... Start non-IC and just be happy with the boost, then once that isn't enough anymore Upgrade the set-up.
(EDIT)
Originally Posted by livelyjay
The only tip you need: Take your time during install and triple check everything before you turn in on.
duck and cover
stop, drop, and roll
good luck with the kit man, definately post a review when your done with install and performance impressions. i want to go turbo so bad right now and this kit is looking pretty good
i thought these kits were actually for the mirage and that one of the pipes was just a slight bit too short and needed some modification to fit. Please correct me if I'm wrong.
I heard that, and I believ it is true... Aside from ghetto-rigging with extra gaskets, I am a welder and I can pretty easily lengthen the pipe with a cut and a coupler. I also read that the AFR isn't worth it unless you get the wide band. Is that true? Would I be fine with just the EGT and Boost gauges?
yes it is true...the AFR gauge is worthless unless u get a Wideband....i got the PLX M300.....it sends a narrow&wideband signal...so the narrow goes to ECU (keeps check engine light off) and the Wide goes to the guage.....probly one of the best Wideband O2 out ther....
edit: that kit seems light....like its missing a lot of stuff....good price though...good luck with it...seems like a hacker kit. (aka building your own kit) how much boost do u plan on running? cause with out the extra fuel you might be running lean and *boom* thats not good.
What the Turbo Specialties Superior Kit comes with :
- 1 Garrett Turbo w/internal wastegate @ 6psi
1 High Nickel Composite Cast Exhaust Manifold
1 Downpipe
1 Fuel Pressure Regulator
1 MAP Unit
1 Oil Return Line and Fitting
1 Air Filter w/piping
Comes with everything necessary to install! Kit is a complete bolt-on!
Originally Posted by rhyzin
you think you can snap pics into the turbo inlet flange? i kinda want to see a better pic of how the manifold is made.
Originally Posted by acs_guitars
How much was the AFR set up, and where'd you get it? the kit is a simple non-ic and is pre-st to 6 PSI. It comes with their piggyback "black box" Map Unit... What other parts should I add to start out staying Non-IC? What I think I need is maybe a BOV and an FMU..... What do you think?
1 Downpipe
1 MAP Unit
