Turbo inlet hose w/ Recirculation port
I'm tired of throwing together home-made pipes that don't work very well. Does anyone know where I can buy an intake hose with a recirculation port (for less than $125) or does anyone know of a good way to make one?
I need one desperately because my bov is blowing back through the MAF after recirculating and causing some stalling issues.
Travis
Travis
the easiest (probably best) way to make one is with a plumbing fitting. Weather your intake pipe is aluminum or rubber / silicone, all you would have to do is use a brass 3/8 nipple fitting (a nipple on one end and threaded on the other), drill and tap (if necessary) to the proper size and install it.
_EVOlved_
12
Jul 13, 2010 09:44 AM
