Have Question on SDs
Old May 20, 2005 | 11:52 PM
viet_tak's Avatar
Ok i'm going to order the stage 2 sds system and it says need a safe header will the RRM Header work for this??? NEED TO KNOW ASAP
Old May 20, 2005 | 11:55 PM
Hotshot940's Avatar
yeah it should, no reason why it wouldn't.
Old May 21, 2005 | 12:04 AM
viet_tak's Avatar
^^^ got a ? for yeah how much HP and WHP are u haveing with the stage 2 Tubro kit??
Old May 21, 2005 | 07:15 AM
Viciouz's Avatar
he's prolly pushing around 230whp or more (thats an underesitmate)
Old May 21, 2005 | 08:28 AM
GreenPsycho's Avatar
a few things: yes, you need an aftermarket header with the SDS system because the stock header/dp combo is too inefficient with FI airflow and causes problems (bottom line: if you like your car, get a header)
the rrm will work, the kamikaze will work, but the rpw header would probably work the best. RRM and kamikaze setups are almost identical, but kamikaze comes with a DP and rrm does not ( you have choice of finishes with kamikaze too). RPW is a touch more expensive, so its up to you
finally, your a 2004, right? which uses the returnless fuel system, right? well, you may want to call ripp and talk to ross about this before you order. afaik, rrm is developing a different kit with different fuel mods for the 04 guys because i don't believe the usual fmu will work
same with the sds (which uses a rising rate FPR), you will have to do some research into that to see.
Old May 21, 2005 | 03:53 PM
viet_tak's Avatar
^^ wat is RPW?? yes i have a 04 so ????
Old May 21, 2005 | 04:22 PM
rpw is another lancer company (in some ways the best). google them for their address
what do you mean "i have an 04 so???" read my previous post dude, i couldn't explain it any more clear than that
Old May 21, 2005 | 04:25 PM
viet_tak's Avatar
who would i got to for the fuel ???^^^^
Old May 21, 2005 | 07:01 PM
i don't understand what you mean, and i think the same is for you
basically, start doing some more research so you understand the difference between the 02-03 fuel system vs. the 04's on up returnless system
Old May 21, 2005 | 08:20 PM
viet_tak's Avatar
well i'm a dumbass and don't understand this fuel shiet!!
but umm doesn't ripp inculde everything??? even the fuel systemchange????
and fuel mod? is it like bigger fuel rail or wat?? and this returnless system i don't get it i search on google and don't understand it please help!!!!!!!
Old May 22, 2005 | 04:18 PM
Blacksheepdj's Avatar
Yes, RIPP includes everything.
But to repeat GreenPsycho, they don't have a kit for 2004 Lancers. So you'd have to work with them to get a kit for your car.
Get it?
Old May 23, 2005 | 11:52 PM
viet_tak's Avatar
ok thanks what a noob i am lol
