Help Boost w/ gauge install on 04 o-z
Old Aug 4, 2005 | 06:52 AM
blaze_125's Avatar
Originally Posted by livelyjay
Sounds like you might have a vacuum leak somewhere. Double check ALL of your vac lines, and make sure to zip tie the tee fitting and at the gauge, so the lines don't come loose.
Maybe not. He says -10psi, which is equal to -20 In. Hg
Old Aug 6, 2005 | 01:20 PM
warpedminds's Avatar
I think your right because the car starts and idles at -10 psi and then the gauge reads 0 at WOT which is right on with what everyone else is saying.
