safe boost levels!
Old Nov 23, 2005 | 02:22 PM
  #31
sweet_bucket22's Avatar
Originally Posted by Blacksheepdj
Yeah, but . . .
EGT is not totally accurate. Lean and rich show certain general EGTs for a given application. But once to get to points of "really rich" and "really lean," the EGTs go the opposite way that you'd expect. So at that point, you start working against yourself because you think the EGT is telling you one thing, but it's actually the opposite.
mmm... okay... i'll buy that. Still says it's a positive at any rate as dsm guys have used them for decades.
Old Nov 23, 2005 | 03:36 PM
  #32
Blacksheepdj's Avatar
Yeah, I'm with you. I'm just saying that you shouldn't take the EGT as being 100% accurate. It's a tuning tool, not the end-all-be-all.
Old Nov 23, 2005 | 03:56 PM
  #33
Alchemist's Avatar
DSM guys have explored the hell out of the platform and can generally tell you what your EGT should be given your mods, that's why they're able to "tune" using just EGT. We don't have that luxury. Don't cheap out, get the AFR meter (I recommend Zeitronix- customer service emailed me back on a Sunday!!). I use the AFR to get, well, the AFR and the EGT gauge to determine how much I can advance timing (more advanced=more heat).
Old Nov 24, 2005 | 05:37 PM
  #34
Aussie CG's Avatar
excuse my ignorance but what is EGT?
Old Nov 24, 2005 | 05:52 PM
  #35
Exhaust Gas Temperature.
Old Nov 25, 2005 | 10:03 AM
  #36
I'm not saying that you need only the EGT... that is definately not true. You need it all if you're gonna self tune or play around on your own.
But even if you have a wideband you could still tune for good AFR and have pinging. Thus a good piggy or standalone that can control timing is needed. However for driveability you will want an OBD-2 reader to get fuel trims happy. Of course if your standalone then you tune for that but a piggy needs to use this item to get things happy. Also to see where timing is at during boost, midrange, low rpms.
The EGT is just another way of combining info to ensure safety and reliability. Same could be said about an Intake temp gauge. Some guys use them as well to see if there intake charge is pushing the limits. All these things will add up to some cash but will allow you the most effective self tune if used together.
If you tune on the dyno via a professional then you don't need most of these. Maybe just a good AFR gauge,wideband to show you that your staying within your dyno'd parameters.
Old Nov 25, 2005 | 04:46 PM
  #37
grubiaco's Avatar
Green are you using an emanage now? I'm thinking about getting an emanage later on, so yea.
Old Nov 25, 2005 | 05:02 PM
  #38
GreenPsycho's Avatar
Nah, i'm using RIPP's blackbox for tuning. If I were to upgrade to anything from here, I would go EMS, but thats if and when I really up the boost
Old Dec 5, 2005 | 09:54 PM
  #39
N20Lancer's Avatar
where can you get the emanange?
Old Dec 5, 2005 | 11:16 PM
  #40
Lancerguy'03's Avatar
www.greddy.com
Old Dec 12, 2005 | 09:50 AM
  #41
XAlliedYouthX's Avatar
So with a packaged kit like RRMs turbo or the SDS Supercharger would it be safe to say that you could run their recommended boost levels and not require you to do any other tuning?
Old Dec 12, 2005 | 10:01 AM
  #42
that is correct. both kits come with pretuned boxes, so no outside tuning is recquired at all. just plug everything in and install everything and you are good to go.
Old Dec 12, 2005 | 11:58 AM
  #43
Greenphsyco didn't have anything bad to say?
Just kidding... I will add that one nice benefit of the RRM is that you'll get the software with it to do custom tuning if you'd like later on. It will also come with the base maps. RRM is releasing the software as of the 1st of the month {thumbup)
Old Dec 12, 2005 | 12:25 PM
  #44
gregivq's Avatar
And let's not forget RRM's great customer service to help you with problems down the road.
GreenPsycho, you actually didn't say anything bad. I'm suprised. REALLY!
Old Dec 12, 2005 | 12:33 PM
  #45
Lets not be hasty, if you search deep, there are some (a few, but still) threads of where RRM screwed over some people something awful. You just don't hear about it much.
see above, problem rectified, sorry for my lapse, I hope bucket and you can forgive me
