t-25
Old Feb 27, 2006 | 06:40 AM
turboturd's Avatar
t-25
hey wassup guys, i have a 96 sc2 that im currently in the process of turbocharging. my friend has a 04 lancer es he wants to turbo also. so i joined the evolutionm community to find out about his car so i can help him out.
ive read up about the pros and cons of the tsi kit. the cons are not that bad, but i need to find out a little about the t-25 that it comes with.
i know how to read a compressor map and ive plotted rpm points for his engine and from prior knowledge know that the t-25 is way to small.
so question 1 is actually three part :what rpm does it start making boost, make full boost, and when does it run out of steam
question 2 is about max boost and horsepower on stock internals. on the threads i have read that lancer's can hold about 12-13 psi w/stock internals. thats is all fine and good but 13 psi on a t-25 is not 13 psi on a t3. it doesnt matter how much boost you run, but how many horses it takes to break things.
for example if i ran a t3 off of a saab i could run about 12 psi and make 200-220 hp,which is where things start breakin. i also could run a t3/t40e at 7 psi and make the same numbers. so i actually need to know what kind of ponies your engines can hold stock rather than psi because we may still go fully custom.
any feedback would be helpful
Old Feb 27, 2006 | 07:34 AM
Blacksheepdj's Avatar
12-13 on stock rods
pistons get iffy around 10, from what I've heard. But as always, different cars give different results.
HP before they blow - we really don't know. Generally when a Lancer blows, it's something like "turned up the boost and went boom" or "my FMU stopped working" or "I used the wrong plugs" etc. Never seen one that just overpowered the internals.
Old Feb 27, 2006 | 08:15 AM
turboturd's Avatar
12-13 psi on a t-25?
not really hp before they go boom just what numbers are being generated at 12-13 psi.
Old Feb 27, 2006 | 08:21 AM
Evodreamer28's Avatar
To be honest with ya for starters a t25 isnt really that bad im running one right now on 8psi tuned a little rich im putting down 175 to the wheels and 200 tq. All stock motor just a 2.5" exhaust still have a high flow cat as well.
Old Feb 27, 2006 | 09:32 AM
turboturd's Avatar
when does boost kick in and does it hold to redline. how far does it hold out if it doesnt go to redline?
Old Feb 27, 2006 | 12:27 PM
Go2fast's Avatar
The turbo spools at around 2700-3000 and falls off at around 5000. Im running a T-25 @ 7psi and as soon as it spools it hits full boost and then falls to 5psi after 5k. If you get a electronic boost controller like apexi you can make up for the loss at high rpms by adjusting the boost up higher at high rps and the fall off would be made up for. My personal advice , Go with the T-28. Thats the best turbo for our cars id say!!
Old Feb 27, 2006 | 03:06 PM
Johns Slow ES's Avatar
T3/T4 for bigger power, it takes a little more time to spool but w/ that turbo u have some growing room if u eventually want to go w/ internals, gasket and run 18 psi
Old Feb 28, 2006 | 05:30 AM
turboturd's Avatar
awesome. thanx for the help guys. i know on my car a t-25 would spool stupid fast like 2k, and i didnt see a big difference between my 1.9 and you guys' 2 litre.
guess i was wrong. oh and go2fast i was planning on using that little trick if whatever turbo he decides on dropped off before the red. dang it, i just remembered. he was asking me about a t3 super 60. any thoughts? if not its okay cuz i already feel like a nagging house wife.
Old Feb 28, 2006 | 05:42 AM
Zippo41189's Avatar
t25 for a sick fast spool but you'll not be over 200hp without pushing it. t28 you can easily get over 200hp, but it spools later than the t25. t3/4 if you gonna go 300hp+ or plan on putting in new internals to make some serious hp. otherwise, the t3/4 will be rather slow to most people's tastes without being used to its full potential.
Old Feb 28, 2006 | 06:24 AM
thereasonsf3's Avatar
yeah thats what im going to do, is get a t 25 non ic kit. then upgrade to a IC kit. then buy a t-28 sell my t-25 pop that sucked in and tune it. im just trying to get into the turbo game so im just gonna start small then build after that.
Old Feb 28, 2006 | 06:29 AM
turboturd's Avatar
cool. ill talk to him again and see what he wants to do
the main problem. money > college students
Old Feb 28, 2006 | 02:58 PM
krnzzang84720's Avatar
I am also turboing my 03 lancer and i am gonna use GT28RS, it spools like t25 and give t28 power!!! planning to install on may/june!! i will definetly put review and pic~
Old Feb 28, 2006 | 06:04 PM
you getting the rpw kit?
98autogstspyder
657
Apr 27, 2022 01:48 PM
Lanart2011
34
Mar 22, 2016 11:50 AM
Vesanity
Lancer Engine Tech
Jul 10, 2014 02:26 PM
RedLanEVO
Sep 8, 2006 03:38 PM
