RRM 04 Turbo Kit Install
Went to the track today, it was packed so i only got to do 3 runs.
Setup:
tires 25psi
removed subs & spare tire
boost 8psi
1st run , i am on left lane, the other car was i think a vw jetta turbo
2nd run was 15.5, trap speed 93, grinded 2nd gear
3rd run was 15.7, trap speed 94, tried to actually launch it hard and i sat there spinning & wheel hoping, bad idea
sometime this week ill be putting in the short shifter and stage 2 clutch, and also getting my exhaust done, i still have the stock pipe from the cat to the rear axle.
Im kinda disapointed i only got 3 runs because the next test & tune is not for another couple of weeks, hopefully ill get down to mid 14s
till next time
Setup:
tires 25psi
boost 8psi
till next time
Not a bad reaction time there. And if you really want some bragging rights, I know a guy that has an SRT-4 and can't drive it right, so you could kick his @$$ on the 1/8 a few times and post the slips. LOL
Little more tweaking and a few more parts, you would be able to dip into the 13's.
just the turbo, i have no other mods other than the 2.25 custom pipe from the rear axle to the mufler, but like i said i still have the stock pipe between the downpipe and that.
