Just Bought Turbo Kit. Need Some Advice Pls
Old May 15, 2006 | 08:37 PM
AJsGenerX's Avatar
Its the same exact turbo that comes on a stock eclipse turbo. It heats up soo fast after hitting full boost and spools so little air that we (dsm community) call it a hair dryer. It is by far the worst turbo to buy. If anything, upgrade to a Big T-28
Old May 15, 2006 | 08:46 PM
AJsGenerX's Avatar
If you are not gonna run an intercooler then forget about anything bigger than a T-25. T-25s are great for local driving around town and pulling hard but after a while and full boost, it starts to blow hot air and causes detonation. Its not that great.
Old May 15, 2006 | 10:38 PM
Z_Lancer_Man's Avatar
Do you have both the oil and water lines hooked up to the turbo? That will help keep it a little cooler - I've been debating adding the coolant lines to my T28....
Old May 16, 2006 | 08:12 AM
Sicktght311's Avatar
You have to also take into account the difference between DSMs and Lancers. You are boosting close to double the psi on a DSM than you are on a lancer so of course the heatexchange is going to be a lot higher. That high of numbers you are surely running into the limits of the turbo on a dsm, but on a lancer like it has been said, the T25 does not come close to it's limits on a non IC, let alone a mild IC kit. It is best suited for moderate power for everyday driving. If ya want big power go for the full 16g setup
Old May 17, 2006 | 03:37 PM
N1te's Avatar
You bought this kit on ebay didn't you?
Old May 18, 2006 | 07:18 AM
The starter of this thread bought the kit on ebay. I bought the turbo and manifold off him. The rest of the stuff for my kit has already been fabricated and or installed
