Turbo Set up (All Parts from RRM)
Old Jun 9, 2006 | 08:47 AM
TougeOZ_04's Avatar
ROAD///RACE TURBO KIT FOR OZ, LS, ES 04-06 $3999
RRM Piggyback Controller Software (CD ROM) $49
ZEITRONIX WIDEBAND $279
ROAD///RACE Light Aluminum Crank Pulley $99
Lancer Magnacore Wires $89
Total $4515
Couple questions also,
1. Does the turbo kit come with injectors or fuel system?
2. Is this everything for tunning so i don't F**K up my car?
3. Do i really need a wideband for tunning or the that software do the same thing?
Yes i am a NOOB, i was planing on superchagering but if they don't make it i'm not
going to brother. So i really don't much about turbos!
Old Jun 9, 2006 | 08:56 AM
Wallesasuaz's Avatar
The kit brings everything you need to just bolt it on. You gotta buy the wideband seperately. along w/ EGT, Boost, and AF Gauge. The kit also brings a PIGGY.
as for everything else, someone will come along and answer more thoroughly...
Old Jun 9, 2006 | 08:58 AM
ambystom01's Avatar
The stage 1 turbo doesn't need injectors, it does however come with upgraded fuel pump and fuel management unit. You don't need the crank pulley or magnecore wires, you'd be better off upgrading the intake manifold, exhaust and the TB, if you haven't already. If you're going to tune, you need a wideband unless you want your engine to explode.
Old Jun 9, 2006 | 09:04 AM
uranium9v's Avatar
and there is a lancer supercharger out there. Search for Ripp mods
Old Jun 9, 2006 | 09:13 AM
there was just a thread started that it was supposedly pulled from production.
Old Jun 9, 2006 | 09:21 AM
TougeOZ_04's Avatar
What's TB? (NOOB YES)
i'm noting looking for tunning i just want to turbo my car to make 200 hp(or at least)
How much PSI does this kit produce?
Old Jun 9, 2006 | 09:23 AM
Sicktght311's Avatar
Someone should make a sticky about what a wideband really is because everytime a self proclaimed "newb" comes out they refer to a wideband as something used to physically tune the car, like a computer or something to control the fuel curves.
Wideband refers to an oxygen sensor that can more accurately measure the A/F ratio in your exhaust to determine how rich, lean, or stoich you are running. This is called "wideband" because it has a wider range of accuracy than the stock o2 sensors used from the factory. These we call narrow band and they are only accurate to a very small amount, not good for precise tuning.
The best description i ever heard came from the riceboys at honda tech.
Wideband vs narrowband is like taking your temperature with a thermometer.
The Narrowband thermometer would only really tell you 3 things 1) you have a fever, 2) you're fine, 3) you have hypothermia, but whether you are hypothermic with an 86 degree temp or a 90 degree temp it will not tell you, it will just say, you're gonna die
The Wideband thermometer tells you what exact temperature you have from a range of like 86 degrees to 112 degrees to the decimal point
So after this long rant, 02 sensors are used to measure a/f ratio, wideband o2 is precise, narrowband is general. And we use either one as a focus point so we can use the tuning software (piggybacks, safc, etc etc) to actually change those numbers by adding and subtracting fuel at certain points along your RPM curve.
Snoogins
Old Jun 9, 2006 | 09:32 AM
TB - Throttle Body
IM - Intake Manifold
WB - Wideband
NB - NEWB
Old Jun 9, 2006 | 09:33 AM
TougeOZ_04's Avatar
Snoogins
that helps out alot more, i'll prob just get it thankz
Old Jun 9, 2006 | 09:36 AM
prob? just get it, it'll come in very very handy.
Old Jun 9, 2006 | 11:10 AM
civilrage's Avatar
WORD
Old Jun 9, 2006 | 04:03 PM
Silens's Avatar
you definatly want to upgrade your exhaust if you havent already, the kit comes with everything you will need to install it and boost away, except a boost gauge you want to get one of those so you know your running a safe boost level, which is 7psi on this kit, if your planning on tuning it yourself definatly get the stuff that the other guys mentioned, wideband, egt, etc...
btw, the piggy back software comes with the kit.....
Rizaex
102
Aug 1, 2016 05:19 AM
Brian@RRM
May 10, 2011 09:56 PM
Halleys
Sep 18, 2006 12:18 PM
TougeOZ_04
20
Jul 27, 2006 07:21 PM
ROCK
166
Feb 20, 2006 06:11 PM
