A bad thing to see in your engine bay
Old Oct 12, 2006 | 10:31 AM
  #31
Hotshot940's Avatar
i see my engine bay in this thread!
but really, dave, you would be better off patching that sucker up. I'm gonna try to make it home in the next week, we'll have to meet up and i'll take a look at that. If time works on my side, i may be able to get that welded very nicely for you.
Old Oct 12, 2006 | 10:38 AM
  #32
airlinevomitbag's Avatar
If the surfaces were clean and roughed up a little bit JB Weld will work. I know guys with JB Welded engine cases that don't leak on their motorcycles.
Old Oct 12, 2006 | 11:15 AM
  #33
wickdaddy's Avatar
ya that's your engine! had to put the other mentor turbo in here that would be sweet if you could take a look at it...
Old Oct 13, 2006 | 01:46 PM
  #34
jp@shearerfab's Avatar
Originally Posted by Blacksheepdj
After much discussion, we've agreed that this is probably a bad thing for Dave's turbo kit. His complaints of a boost leak might be related...
JB Weld and a plastic cap. And you can wiggle it.
Discuss.
PS - I told you, Dave. Sorry.
I approve only because of the color.
Old Oct 13, 2006 | 01:50 PM
  #35
michaeljr6's Avatar
??????? condom?
Old Oct 13, 2006 | 04:03 PM
  #36
Blacksheepdj's Avatar
JP! I haven't seen you around in like a year!
Dave needs you to do some custom work on his kit. You're the man.
Old Oct 14, 2006 | 10:23 AM
  #37
wickdaddy's Avatar
oh sweet... there is someone that can do good custom work??
Old Oct 26, 2006 | 09:11 PM
  #38
wickdaddy's Avatar
ya so i knocked off all the jb weld from the opening where the pipe was "attached" and put this welded fitting that goes in the hole that has a tube end on it so i could connect the breather to the intake (ill try to post some pics)... sounded like a good idea... so I did it...
then i started it up this morning and headed into work... it was cold, so like most people, I was looking at the temperature gauge to get to the middle so that I could turn on the heat and heat would come out, but all of a sudden the needle started climbing past the midpoint all the way to high so i turned the car off and coasted into a gas station and took off the hose and started it back up and there was no problems.
guess I was sucking the hot air coming out of the breather back into the turbo to heat it back up and then the cycle would continue til my engine heated way up!
Moral of the Project:
DON'T CONNECT THE BREATHER TO THE INTAKE!!
Old Oct 27, 2006 | 07:18 AM
  #39
Originally Posted by wickdaddy
Moral of the Project: DON'T CONNECT THE BREATHER TO THE INTAKE!!
Hey, you tried.
The odd thing is that the breather is connected to the intake when the car is stock. Makes no sense!
Then again, your car is like the mega-Frankenstein build, so I guess I'm not surprised...
Old Nov 1, 2006 | 10:41 AM
  #40
Enjoi926's Avatar
why not just weld it shut
Old Nov 1, 2006 | 02:09 PM
  #41
Obviously because they thought they should retain the stock "valve cover to intake piping" hose.
Old Nov 2, 2006 | 06:35 AM
  #42
wickdaddy's Avatar
it's all good... now I have a custom blackSheep/kfos filter on that bad boy!
Old Nov 2, 2006 | 10:18 AM
  #43
You and Kevin and your love of "custom."
It's a freaking AutoZone filter. Deal with it.
Old Nov 2, 2006 | 08:54 PM
  #44
wickdaddy's Avatar
I might have to back to knfilters.com and get another 62-1320 on order...
Old Nov 4, 2006 | 08:20 AM
  #45
*cough*massivewasteofmoneyyousucker*cough*
Ever get your car unlocked, BTW?
