Please Critique my Setup!
Old Oct 19, 2006 | 07:09 PM
bene's Avatar
Originally Posted by rhyzin
7 psi on a t25 netting 200whp? i don't think so.
200hp ICed at the crank :P its possible
Old Oct 19, 2006 | 09:57 PM
rhyzin's Avatar
maaaaaybe...
pardon. didn't think you'd meant crank. folks don't usually measure that way unless you're stock...
Old Oct 19, 2006 | 10:25 PM
bene's Avatar
yeah i really didnt mean crank but it works
180whp **
Old Oct 20, 2006 | 03:19 PM
bahamut's Avatar
It takes about 10 psi for 2g DSM to get about 200 crank HP. Maybe, if you slap a T25 on a Supra and make the turbo overwork itself. Otherwise, 7 psi is too low for the T25 to make that much power.
http://www.turbofast.com.au/TFmatch.html
This is a good Aussie site matching cars to proper turbo.
Old Oct 20, 2006 | 11:52 PM
mtags24's Avatar
awesome this is really helpful. I would be satisfied making 180-200 whp to begin with. this is my only car so I definitely would want to be upgrading internals soon after and either swapping turbos or cranking the boost up. i think if i change the conpression I can make more HP at the same boost settings
Old Oct 22, 2006 | 06:38 PM
mtags24's Avatar
I've just got one more question. If I am going to have the car tuned by a pro, what will I need as far as hardware is concerned? I would prefer to have an emanage, what else will the tuner need?
Old Oct 22, 2006 | 06:42 PM
bene's Avatar
yes
the pro should have everything he needs to tune it
Old Oct 22, 2006 | 06:49 PM
mtags24's Avatar
cool thanks so.... turbo kit, emanage, a tuner, lots of funds = reliable install and tune
hmm so theoretically I have no use for a wideband, egt, etc if i am not to tune myself right?
Old Oct 22, 2006 | 08:43 PM
phil_'s Avatar
I'd still opt for one, if not, atleast a NB. Just good insurance in forseeing possible problems.
Old Oct 23, 2006 | 06:41 PM
bahamut's Avatar
High CR = better TQ numbers, tends to be better MPG, but harder garnering big PSI numbers. Harder to tune.
Lower CR = easier to reach higher HP w/ bigger PSI numbers. Easier to tune.
