what gauges are needed....
Old May 12, 2003 | 10:19 PM
himuraknshn3's Avatar
Question what gauges are needed....
this might sound like a newbie ? but i'm tryin to get it through my head....i tried searching and everythin but i couldn't find nethin to answer my ?s ...here goes...
what gauges would i need with a turbo setup....name them all and can people give me pricing for them too...much appreciated
Old May 12, 2003 | 10:31 PM
come on i know people are out there....help me out here....
Old May 12, 2003 | 11:02 PM
Liandrin11's Avatar
The most obvious is a boost pressure gauge, probably anywhere from $30-$100. EGT gauge is helpful, others could be oil pressure, oil temp, etc. Most gauges are in the same price ballpark (uninstalled).
Old May 12, 2003 | 11:05 PM
HobieKopek's Avatar
Ok, first 12 minutes != enough time to be whinin' for help again.
Second, you post US Lancer questions in the Evo forum and most people you're looking to get an answer from are going to miss it. Stock turbocharged cars do not require gauges because the ECU is PROGRAMMED to watch all the variables. Anyway...moving.
On top of boost, oil pressure would be good, EGT is damn near essential, and that should be more than plenty.
Old May 12, 2003 | 11:08 PM
coo thnx...sorry didnt' know where to post so i was just lookin at turbo... ....
won't ever happen again ....promise
Old May 12, 2003 | 11:09 PM
stvbreal's Avatar
I would use A/F over EGT.
Then again I am thinking of adding an EGT.
HobieKopek's Avatar
AFR's tend to take time to warm up, no? (besides, the good ones that run their own O2 sensors are very expensive GReddy something like $325 and Tomei something like $425) Besides, chances are he'll be running something like an AFC or E-manage to tune fuel...both of which will give him AFR readings.
Old May 12, 2003 | 11:11 PM
stvbreal's Avatar
So should I replace the AFR with EGT?
Old May 12, 2003 | 11:16 PM
HobieKopek's Avatar
Well...your call obviously, but personally if I ever get an AFR it'll be as a suppliment to the EGT, not the other way around.
Old May 12, 2003 | 11:55 PM
Liandrin11's Avatar
I don't mean to overstep my bounds, Hobie, but even though the thread originating question was pertaining to a turbo setup on a regular lancer, this is clearly a point of interest to Evo owners as well and quite more so I would think seeing as only a very small percentage of lancer owners are going to turbocharge theirs, whereas 100% of Evo's will be turbocharged, 90% of which will be modded to which these gauges will be very important to keep things in check. Just feeling the move didn't seem necessary, but who am I, I suppose .
Old May 13, 2003 | 12:01 AM
HobieKopek's Avatar
Yeah...see my first post. No need for any non-stock gauges in a stock turbocharged car. Hence the move. It's not that I don't want Evo people answering, it's that here he'll get responses from people who've added gauges to the NA Lancer gone boosted out of necessity.
And I don't mind criticism so long as it's constructive.
Old May 13, 2003 | 07:16 AM
LancerO-Z's Avatar
I agree with Andrew. Go with boost and EGT. Go with a GReddy EGT, they have been proven the most accurate EGT gauge on the market. If you have any other questions, just send me a PM, I'll be glad to help.
Old May 14, 2003 | 01:26 AM
jeezer's Avatar
Boost and EGT dude
www.roadracemotorsports.com
Old May 14, 2003 | 01:39 AM
HobieKopek's Avatar
BTW, if cost is an issue, VDO makes very decent gauges at very decent prices. Not the hottest looking, but they do come in white or black face and they're a far cry from ugly...if anything a bit plain.
Old May 14, 2003 | 07:29 AM
LancerO-Z's Avatar
I have a VDO Vision series white face boost gauge. For 50 bucks or so, it works great. It may not be the best looking, but it is accurate.
Plus you don't honestly need 60mm gauges, or the more expensive warning style gauges (unless you plan on just ignoring your gauges until you go over the preset boost and/or EGT temp). Just go with GReddy 52mm Electronic gauges. EGT would be 130-150, and a boost would run you 120-140 give or take. Just search around the net for the best prices. Just something to think about.
