Amby's turbo
Amby's turbo
Ok I finally got around to opening the giant package Lancerguy'03 sent me to check out the turbo. It was very well packed (bordering on excessive
) and everything seemed to be in tip top shape. At the moment I know I need a fuel pump, intercooler, (and intercooler couplers), oil tap fitting, spark plugs, piggyback, oil, and gaskets. Looking at the pics, can anyone see if anything else is missing/necessary?
Looks like you'll be fine w/o any gaskets... It's pretty much all built for ya. Just swap out your stock exhaust manifold and stick that sucker in. Ofcourse, you'll have to modify your A/C for fitment
Well I already have a header so that'll make the swap easier and I don't have AC so that's not a problem. For gaskets I was just going to get the manifold-related gaskets so I don't get a leak.
After talking to Rob I'm just gonna use a piggyback to tune the car so I don't need a decompression gasket. Plus I'm not running high boost (only 5.8 PSI) so it should be alright, hopefully.
ahh i see. i didnt know that because im used to seeing them like this: http://store.racinglab.com/bov-hks-1421-sa001.html
WOW, what an Odd manifold design, not saying it is bad, just like a full loop.
The Only thing I can say to do is get rid of that plastic BOV, it leaks and doesn't seal at all, just plastic on plastic. Get an OEM Evo IX BOV, all metal and it'll hold well over 20PSI.
That's because instead of a tubular manifold, it uses the RRM header which they made compatible for their turbo kit. That why if you were progressing and had the header first, you would just need that up/downpipe for the turbo and not a new manifold...
