05 lancer turbo kit fuel questions
Old Feb 14, 2007 | 01:53 PM
hypnoticauto's Avatar
hey guys i got a kid wanting me to throw a turbo kit he has asembled on his 05 lancer es, just need to know if this has a fuel return so i cna use an fmu. i havnt seen the car yet i just know what he has for parts
Old Feb 14, 2007 | 02:36 PM
Silens's Avatar
negative, the 04+ have a returnless fuel system
Old Feb 14, 2007 | 02:40 PM
dang, wonder what i can do now to keep this thing cheap for him. i am in maine and fast and the furious is just hitting so everyone wants a bov
Old Feb 14, 2007 | 03:29 PM
grubiaco's Avatar
I've seen returnless conversion kits.
Old Feb 14, 2007 | 03:34 PM
anyone know where i can find one of these
Old Feb 14, 2007 | 03:35 PM
or an inexpensive tuning option he is using a chrysler t3 turbo and will neverb oost over 7 lbs it is intercooled custom manifold and downpipe
Old Feb 17, 2007 | 05:04 PM
anyone know of cheap tuning for the 04+
Old Feb 17, 2007 | 05:40 PM
Silens's Avatar
Originally Posted by Mitsiman
You cannot fit a FPR unit to the vheicles which are returnless systems. Only the earlier models which did run a stock FPR setup. Using a FPR stock type 1 : 1 ratio unit is of no real value - a rising rate FPR unit under vacuem is what you would be after.
We instead setup on our turbo cars a surge tank system with a larger pump to avoid problems with the fuel pump and returnless system on the lancers - this way we used the stock pump to fill up the surge tank, setup a return line system and then fed it back to the petrol tank. Worked a treat.
Im also trying to figure out what to do, so far we have decided to go ahead and convert the fuel to a return system ( tap fuel rail to run a return line, install a fpr and run power straight to the fuel pump ), if that doesnt work we will be giving the surge tank idea a shot.
And if neither works i guess well try this Aeromotive Digital FMU suposedly for returnless systems.
Old Feb 17, 2007 | 06:23 PM
id like some more info on converting to a fuel return system, what parts do you need, pump housing for tank? 02 style rail?
Old Feb 18, 2007 | 11:22 AM
Silens's Avatar
02-03 fuel rail wont fit 04s, the injectors are spaced differently, if you wanted to go with an 03 fuel rail im pretty sure you would have to get their intake manifold too.
As for the conversion i cant give you any more info because i havent done it yet, and if somebody has done it , they havent posted on the forums , i will be doing it within this next week, i will try to take some pictures and all that.
Old Feb 19, 2007 | 03:21 PM
ok cool this kid just wants it done right if i can save him some cash by being on here it is worth it
Old Feb 20, 2007 | 05:20 AM
TougeOZ_04's Avatar
Rrm
Old Feb 20, 2007 | 09:49 AM
Silens's Avatar
well we were looking at the fuel rail last night, and it is way too thin at the end to tap for a fitting, which means a new fuel rail needs to be made, or find one that fits it
If you only plan on runing 7psi you could talk to RRM about getting the fuel setup they use for their 04 turbo kit, but it wont be cheap, they use a 5th injector in the intake pipe with their piggy back
Old Feb 20, 2007 | 12:38 PM
Go2fast's Avatar
Here, go to this website below, its vortechs. I worked on a bunch of dodge trucks and jeeps and the earlier models had a non return fuel system similiar to the 04+ lancer. You can do the same thing to the lancer as we did to trucks when boosting. This is the manual of the full install of the kit on a jeep but only pay attention to page 16 and 18. There are diagrams there that show you two ways you can hook up an FMU to an non return fuel system. You just have to get a aux pump to make it work.
http://www.vortechsuperchargers.com/pdf/manuals/4CJ218im.pdf
Old Feb 20, 2007 | 03:31 PM
well that looks all to easy do you know what the flow capacity of this origional pump needs to be and do you also need the walbro in the tank?
