are these the right spark plugs for my turbo?
Old Apr 2, 2007 | 12:10 AM
kungfugirl's Avatar
edit:
I am retawded
found the plugs here for cheap!!!:
http://ngk.carshopinc.com/product_in...id/81166/BKR7E
Old Apr 2, 2007 | 12:12 AM
yellance's Avatar
yep those are correct
Old Apr 2, 2007 | 09:39 AM
SLVROZ_03's Avatar
Can't tell from that site, but shouldn't a turbo'd car have a single step colder plugs? I know my turbo'd Civic will run a 2-step colder NGK plug.
Old Apr 2, 2007 | 09:51 AM
Silens's Avatar
Yes they are, you should be able to get them form Autozone no problem, the one i go to had them in stock .
Old Apr 2, 2007 | 10:07 AM
iyi0521's Avatar
Autozone you say? Do they have to be regapped or are they gapped properly when you get them?
Old Apr 2, 2007 | 10:16 AM
kungfugirl's Avatar
i think we need to gap them to .30....
.44 is what they come, no?
Old Apr 2, 2007 | 10:27 AM
kungfugirl's Avatar
just a random question guys, where can we get the fittings to tap and feed the return line to the oil pan, i have the actual plumbing from the turbo i just need to tap the pan etc.
Old Apr 2, 2007 | 11:44 AM
Go2fast's Avatar
1. The plugs are correct if your running a none turbo. If your running a turbo you need to run a NGK BKR6EIX. Its one step colder. I regapped mine to 0.35. Its also an iridium plug and a little pricey but well worth it.
2. As for gapping 0.30 is way to low. Look at the sticker underneath your hood. It say like 0.36-0.41 i think. Thats for stock or non turbo. You want a smaller gap when turboing.
3. As for the oil return line plumbing, Just remove the lower oil pan and have drill a hole in it and weld the fitting in. This way you know it wont leak.
Old Apr 2, 2007 | 01:04 PM
iyi0521's Avatar
Just make sure you mark where you want drilled and double check your mark or else youll need a new pan like me.
The pan i drilled works it just sux. I need a new one.
On topic: i thought the bkr7e's were two steps colder plugs then stock?
Old Apr 2, 2007 | 06:34 PM
kungfugirl's Avatar
rrms istructions say gap to .30 and i thought i just needed 1 step closer.
and as for the fitting, where can i find the fittings to hook up the drain?
Old Apr 3, 2007 | 09:10 AM
Go2fast's Avatar
The Bkr7e's are the evo plugs. Everyone has them listed wrong for the lancer. Our stock motor runs a 5 series plug. By NGK standards, the higher the number the colder the plug. So a 6 would be one step higher.
As for the drain just go to the hardware store.
Old Apr 3, 2007 | 10:21 AM
kungfugirl's Avatar
so the stck is 5, and the 7 is two steps colder?
Old Apr 3, 2007 | 06:38 PM
kungfugirl's Avatar
so wait you went one step colder not 2 like a reputable company like rrm gives with theyre kit??? is this effective... i went to pep boys and autozone and no luck with the ones suggested.
Old Apr 4, 2007 | 12:33 AM
kungfugirl's Avatar
bump
Old Apr 4, 2007 | 10:43 AM
SLVROZ_03's Avatar
Searched the given stock # on Ebay and came up with this... ( http://cgi.ebay.com/ebaymotors/4-New...spagenameZWDVW ). Neon?
