Effecting the engine's life with turbo
Old Jul 7, 2003 | 07:03 AM
i_love_spool's Avatar
A little while ago I saw an ITR in a magzine that used a Motorcycle Exhaust as a wastegate. The exit was directly in front of the front wheel. I was just wondering if this was a viable modification? It has nothing to do with "looking" cool, but this guy was an engineer so I assume there was something to be gained from this......
Old Jul 7, 2003 | 07:18 AM
HobieKopek's Avatar
As a dump pipe maybe, but (unless I'm just not understanding correctly) and exhaust is just piping while a wastegate is basically a pressure actuated valve.
Old Jul 7, 2003 | 07:25 AM
Must have been a dump pipe....nonetheless what is the value of having a motorcycle exhaust as a dump pipe exiting in front of your left front tire?
Old Jul 7, 2003 | 07:30 AM
raul's Avatar
I third that! Turbo requires a little more effort to take care of but it is only the guys who get greedy that get bit! Car should be fine as long as you follow recommendations!
Old Jul 9, 2003 | 11:27 PM
Boeturbolancer's Avatar
Exactly... this greed/overboosting has had some people digging deep into their wallets. Just need to say NO!!
Old Jul 11, 2003 | 08:42 AM
JJLANCER02's Avatar
IM ONLY 17 AND I HAVE A 0Z LANCER 02 AND WAS THINKING OF PUTING A TURBO IN IT IT'S AN AUTOMATIC AND THE ONLY THING I HAVE IN IT IS AN INTAKE AND EXHAUST AND WHAT CAN I RUN WITH EVERY THING STOCK ON THE TURBO WHAT PSI THANKS
LOVE YOUR CAR BOE
Old Jul 11, 2003 | 09:03 AM
6PSI
Old Jul 11, 2003 | 09:04 AM
Which would be around 170WHP!
Old Jul 11, 2003 | 09:17 AM
customlancer's Avatar
with ported & polished heads and intake manifold, forged pistons, all the "bolt ons," all new internals, camshaft, cam gear (stage 3), bigger fuel pump, injecters, RRM intercooled turbo, etc.. would it be possible to get up 12-16 lbs of boost? or is that asking for too much?
Old Jul 11, 2003 | 09:28 AM
Guru_Del's Avatar
prolly too much. you would also need new head bolts (which RRM could source for you) as well as some other items. 16 is alot of boost.
Old Jul 11, 2003 | 09:31 AM
Link286XT's Avatar
you would have to lower the compression ratio, have some kind of computer management, lsd, and lots of $$$
Link
Old Jul 11, 2003 | 09:42 AM
Have yet to test that high. Our max goal is going to be 10psi. Not that you have to lower compression but items like rods/crankshafts/tranny etc are limiting factors. Many will get pistons but don't want to get rods so we are concentrating on that. With rods and head bolts i'd say you could run up to 15 max. Its all about tuning for it. If your serious about it and get all that you said done then you can get kit from RRM and RRM will assist you in going to that limit. I know they'd like to see it happen! Right now we are focusing on 10psi!
Old Jul 19, 2003 | 04:10 PM
veturrapresto's Avatar
so basically if you spend the money to get a non IC turbo kit from rrm, get it put in, you can expect your car to run fine with no problems? hows maintence, hard to find a good mechanic in my area, i want some more speed but i dont wanna go nuts, but i think the 5 or 6 boost form the turbo will meet my needs fine, i just wanna go a little faster, im not about to kill myself, or get greedy for more speed, bc if thats the case ill just save my money for a better car.
Old Jul 19, 2003 | 06:44 PM
Exactly right... don't be greedy... change your oil/filter every 3k and make leak/visual inspections often... maybe every 500 miles or after long trips/hard runs. Other than that nothing you need to do. If you have no leaks after a couple oil changes you can tame down your checks unless you bottom out/hit something/ etc.. Simple!
