VTA BOV on Lancer
Old Aug 16, 2007 | 12:24 PM
  #46
ambystom01's Avatar
Thank god someone actually got it.
Old Aug 16, 2007 | 12:58 PM
  #47
crypto's Avatar
Former Vendor
I assumed this was common sense stuff. guess not
Old Aug 16, 2007 | 01:00 PM
  #48
ambystom01's Avatar
Common sense is not so common.
Voltaire
Old Aug 16, 2007 | 01:38 PM
  #49
mitsuozboi's Avatar
ha. this thread was funny to read. Good info though cause it is something that a lot of people dont understand.
Old Aug 17, 2007 | 09:22 AM
  #50
manny_fresh's Avatar
Thanks all for all those comments. I don't think i will be vta my Bov anymore
Old Aug 17, 2007 | 09:24 AM
  #51
ambystom01's Avatar
If you want to make the stock one (or rather the one that comes with the kit) louder, try opening up the intake side some more. Do you have a bored TB and IM? I know with the evos and the WRXs if you replace the stock airbox the DV becomes very audible.
Old Aug 17, 2007 | 09:32 AM
  #52
^No i don't...
Old Aug 17, 2007 | 09:34 AM
  #53
ambystom01's Avatar
Well those things might make it a bit louder, at the very least they'll add power. I have a stock IM I can give you for cheap (ie. you pay shipping) cause god knows I don't need it. You could then either port and polish it yourself or get it done professionally, should save you some money that way. Then get the TB from RRM and you're set.
Old Aug 17, 2007 | 09:37 AM
  #54
SLVROZ_03's Avatar
Funny, I just saw this thread right above yours...so thought you might like to ckeck it out ( https://www.evolutionm.net/forums/sh...d.php?t=285699 ).
Old Aug 17, 2007 | 10:52 AM
  #55
^i love the sound on that bov, but i am pretty sure it won't sound like that recir.
Old Aug 17, 2007 | 11:12 AM
  #56
crypto's Avatar
Former Vendor
yeh that sound would def get annoying. but it's your car. so go nuts. lol
Old Aug 17, 2007 | 11:15 AM
  #57
lancerman360's Avatar
Yeah me too.
Old Aug 18, 2007 | 09:57 AM
  #58
cincy's Avatar
Originally Posted by ambystom01
I was referring more to cincy's comments. I would really suggest recirculating. If you want a different BOV I've heard the JDM MR DV works well, is a direct swap for the one that comes with the RRM kit and sounds better.
I hate to break it to you...BUT, the subie link lumped all bov's together...which they arent. And you helped my cause with that link from here. The guy is using a 50mm tial bov...."The only valve I know of personally with a larger diaphragm than valve disk is the TIAL. I will never use anything other than a valve that has a larger diaphragm than the valve disk because unless there is a diaphragm failure it is impossible for it to leak no matter what boost pressure you throw at it. With a valve that has a smaller diaphragm than the valve disk to run high boost you need to run more spring pressure, and eventually you end up with so much spring pressure that the valve doesn’t open very far when vacuum is applied to the top of the diaphragm and this limits the ability to vent enough of the pressure wave to prevent the pressure wave from hitting the turbo. I just wish you could get a TIAL with a recirculation kit.... but the valve is gigantic even vented to atmosphere and would be even bigger with a recirculation setup" THANKS!
As for the comment on the bad idle, its because your leaking air that should be going into the engine at idle, THUS THE REASON FOR A TWIN PISTON OR SSQV. These will keep the bov closed at idle and keep the car from running rich between shifts. These valves can only be opened if there is pressure in the ic pipes.
Old Aug 18, 2007 | 10:31 AM
  #59
ambystom01's Avatar
And? We don't know what other mods that guy has and we don't know if he has problems. Given that he is running a TIAL BOV and given his general attitude on NASIOC he probably has a heavily modified car and may indeed by using a MAP system.
What about between shifts? How does it keep it from running rich between shifts if it is still getting rid of metered air?
At this point I don't care because it's basically your word against hundreds on evom, thousands on NASIOC, as well as the countless threads you can find online showing the problems of using a VTA BOV on a MAF equipped car. I don't usually like to play the numbers game but in this case you don't stand a chance. If an evo tuner says not to use them, I'd tend to agree. When I searched VTA BOV it was literally vendor after vendor saying not to use them.
Old Aug 18, 2007 | 10:46 AM
  #60
cincy's Avatar
From Mike@Forge, what i currently run.
Originally Posted by Mike@Forge
Dual Piston:
Our dual-piston type valves are only for those applications which can accept the use a valve that will vent at throttle lift, however, it should be noted that, the dual piston design (which I will explain below) prevents the valves from being open at idle, yet does not suffer some of the same issues as those mentioned above for the HKS valve.
The dual piston valves, while being compatible with both Speed Density and MAP engine management systems, are also designed to aid in compatibility with those rare MAF applications that are tuned to allow for the use of an atmospheric valve, however, we make no guarantees to compatibility with all MAF applications.
At idle or under vacuum, only the main piston is "pulled" open by the vacuum from the intake manifold. Since the secondary piston, however, is counter balanced against the main piston with a smaller spring, it remains sealed preventing the minimal amount of already metered pressure within the intercooler piping at idle from escaping the system.
Under load/boost, both pistons are "pushed" closed by the main spring pressure and pressure reference from the intake manifold, thus creating a seal and holding boost.
At throttle lift, though, the return of the intake manifold to vacuum will "pull" the main piston open and the residual charge pressure will "push" the secondary piston open, allowing the air to be vented without any issue.
I have worked up somewhat of a diagram below:
But for people that rather not risk it or just be a little louder, the Forge Splitter is a hybrid valve i mentioned in my first post. If only vents about 10% of the air and that port will be closed at idle. This means that you wont have idle issues or any rich issues. I own this one also and it has a clean blow off and a good bit louder than a dv. The best thing is that it is easily adj for the person before that couldnt get the greddy to work.
