turbo ?
turbo ?
say i buy a non-ic turbo from rrm and then i install it. does the turbo automatically come set at 5 psi or do you have to tamper with it to set it. if so how? p.s. dont laugh at me!
Boost controller is actually a regulator that bleeds pressure out of a line that goes to the wastegate. The wastegate has a set spring which controls how much boost you make. If you bleed off the pressure to this spring it then takes more pressure to open meaning more boost. Boost is determined by how much you bleed off the line. The more you bleed the more you raise boost. There are specific things that are involved in this to prevent turbo lag or late boost and boost creeping or slow rising boost. These things come with the boost controller. Hope this helps you out!
Wow Boe I have been reading all your posts and i really appreciate all the info! You should write up a "turbo: for dummies" article that goes over all the fundamental stuff. It really helps out a lot!
