Aquamist - water cooling to delete IC
Hey guys, I've been searching and can't find any really good answers to this question.
I talked to Rock a while back (like a year) about turboing my OZ with the IT VII conversion. Anyone who knows this conversion knows that there isn't room for a FMIC let alone the piping to reach the IC if you happened to get one small enough.
I was searching other options for running Non IC and came across water injection. Same stuff the Evo guys use to run water/meth. I was wondering how safe it would be to run on our Lancers considering the weak bottom end. I figure running all water, no meth has to be safer than running Non IC. Any input would be great, thanks.
I think you'd be better off running a non-ic kit from RRM. The problem I have with water/meth injection is that first off you need to be tuned for it. Secondly, if you run out of water/meth for whatever reason (tank leaks, you forget, etc.) you can kiss your motor goodbye. I'm not sure on what kind of stress it puts on the motor. Lastly, the install is a pain, you'd need to find a suitable tank to hold the water/meth, mount it, and hook all the lines up.
I see what your saying, and it makes sense, but living in Las Vegas I see a problem running non-intercooled. Do you know if it would be possible to run only water? Maybe you saying that it's not a good idea is a sign, because I've been contemplating giving up on the Lancer and saving for an Evo, or turboing the Lancer. Hmmm.
Well let me put it this way, I wouldn't personally do it. Most of the people I know using a meth/water injection also have an intercooler. I think the RIPP supercharger used a methanol injector system but I'm not sure how efficient it was. With the amount of boost you'd be running I can't see it being worth it personally. Just doing a quick search, I found this article http://www.rallycars.com/Cars/WaterInjection.html. It doesn't mention at all people using meth/water injection alone, ie. without an intercooler.
Yeah, I was reading up on Snow Performance's website and all the examples they gave seemed to be on cars that are running intercoolers. It only said once that watercooled would reduce air temps, but running with an intercooler produce an even cooler charge. The only time I've even heard of just watercooled no intercooler was in an Import Tuner or something a while back, saying that not many people do watercooled since intercooled is more popular and doesn't need to be monitored as often.
Hmm, question answered. Hopefully this helps someone and I wasn't just sounding like an idiot.
Well, I'm not completely done weighing in the pros and cons of saving for the Evo or turboing the Lancer, so that someone may be me. It would just seriously bug me running non IC in Vegas heat. My mom said it hit high 120s this summer while I was out here for school.
If I do go turbo and end up doing this, I'll be sure to post for all of EvoM to see!
Ambient air temperature doesn't mean much when you're boosting. A compressor wheel spinning at 100,000 rpm is going to heat up the air to "pretty freaking hot." Doesn't matter if that air started out 10 degrees or 120. AND turbo systems are run by air from the exhaust of the car. Last I checked, that air was pretty hot too.
Being in Vegas is not a reasonable excuse to me. But maybe I'm nuts. But I know that RRM is located in Southern Cali and they have no problem selling non-IC kits to the locals...
Honestly, why?
A dsm side mount actully fit rather well for me behind the drivers side vent. Works especially well if u relocate your battery. Unfortunatly mine was damaged and is now usless.
Why don't you be one of the first ones to install a rear mounted turbo??? No intercooler needed because with the turbo installed outside of the engine bay, temperatures are cooled down just like you had in intercooler.
