ayone use these injectors?
Old Oct 9, 2007 | 11:02 PM
kungfugirl's Avatar
http://www.atpturbo.com/Merchant2/me...egory_Code=FUL
Old Oct 10, 2007 | 10:00 AM
SLVROZ_03's Avatar
Not sure if the "Bosch" style will fit the fuel rail. I know on Hondas, there are Bosch inj. fuel rails that are totally different than stock. So I'd be afraid of trying them...
Old Oct 10, 2007 | 10:30 AM
kungfugirl's Avatar
Guess ill stick to stock wrx.
Old Oct 10, 2007 | 10:47 AM
Speed Corps's Avatar
Former Vendor
You would probably have to cut a spacer to raise the fuel rail up for those to fit same with the Honduh injectors. I am gonna measure it up and cut some spacers myself.
Old Oct 10, 2007 | 01:48 PM
c900t16's Avatar
i used to use Bosch injectors on my saab. Although they came with sotck Bosch injectors, i hated them and all i could really upgrade to was another set of Bosch injectors...They always crapped out on me for some reason, or they didnt flow right. I had a problems with them that caused huge drivability issues when i put in a new set! Then i got another set for free from Bosch since they were deffective form the get go.
Old Oct 10, 2007 | 02:07 PM
Former Vendor
There are more options for injectors. I know that the wrx injectors work, and of course anything aftermarket for the wrx but they are pretty pricey. You can use the honda ones, once I make some spacers, I can make them available. There is also a way to use stock injectors from DSM's but you would have to use resistors in line on the hot wire of the injector and spacers. Alot of the aftermarket DSM injectors are fairly cheap too.
Aniel
Feb 5, 2016 07:08 AM
OakosAutomotive
EvoX 'For Sale' Miscellaneous
90
Jun 5, 2014 01:24 PM
OakosAutomotive
Evo 'For Sale' Miscellaneous
88
Jun 5, 2014 01:17 PM
Eisen7
Apr 6, 2014 08:15 PM
ecuflasher
11
Nov 7, 2008 09:24 AM
