HKS turbo kit at SEMA
I would love to see some dyno numbers from any of these projects that are being worked on. Even more so I would like to see how a cvt would respond to the turbo. Unfortunately i dont think the CVT will handle too much torque. Im sure they will respond well it will just take a good bit of tuning to get this right, so the engine doesn't go boom.
Maybe, maybe not. It could be holding back on the PSI and a small turbo and has a killer tune(Tuning is the key in any car not just the engine specs). Maybe all they did was lower the CR slightly. But wont know for sure until someone releases the specs......
Now if you are wanting huge power numbers, then you will have to start looking at forged lower cr pistons, stronger connection rods and crank. stronger head bolts and a complete upgrade of the fuel system. At that point you would have been better off going with an evo.
Here are my pics i took
Cant tell if its really turbo charged.
The booth it was in wasn't a HKS booth. From what i saw it wasn't turbo. But i didn't pop the hood and the guy acted like it was all show
Maybe as dressed up they have a base model(hence no wing or foglights)with a GTS bodykit and wheels.
Edit:didnt see those pics you posted before I posted this, that does like sick with that front mount tho
I dont buy it.... you can definately see the manifold, but you can argue you cant see the turbo(big whoop alot of kits you cant see the turbo), but you can see the oil lines and what not, sure you cant see the intercooler pipes above the engine, maybe they went underneath???
Maybe as dressed up they have a base model(hence no wing)with a GTS bodykit and wheels.
I would like to know to
Although they will probably pull some crap saying they cant say or some other load of crap that manufacturers like to do
Still has the same effect as a turbo.
That car i saw there i thought was a evo x the guy in the both said no its a lancer with allot of dress up parts and is the bosses daily driver.
From the other pictures of the car (see the first post), it definitely looks turbocharged. And if it's daily driven, I gotta figure that those parts are the real deal, or else it wouldn't even run...
FWIW, giving the interior picture a close look, it kinda looks like that's a boost gauge on the left. Doesn't necessarily mean anything, but it does lend some credence to the boosted theory...
