Yet another boost problem!!!
Old Jan 9, 2008 | 12:20 PM
senate6268's Avatar
Don't forget that you will have a pressure drop with your intercooled setup. Usually about 1psi. I initially saw 4psi on my 16G6 setup with a 5psi wastegate spring before I installed my boost controller. Also, I see full boost in all gears (11-12psi). I'm easier on the pedal in the lower gears to keep traction and still pull hard.
Old Jan 9, 2008 | 12:27 PM
Mirage2.0's Avatar
^I know I know, Like I said I did see .47 pound (3rd gear) on the dyno on every run.
Old Jan 9, 2008 | 01:02 PM
cincy's Avatar
5psi is excessive. Your ic piping is probably 2.5" and is 0.25-0.5" to big causing both lag and pressure drop. Your ic could also be to large, but the piping is a bigger cause of pressure drop. 2" from turbo to TB should be plenty big, if you want, 2" to the ic and 2.25 to TB should also work.
Old Jan 9, 2008 | 01:13 PM
ambystom01's Avatar
He's only losing 1 PSI, not 5.
Old Jan 9, 2008 | 01:35 PM
cincy's Avatar
i guess i read that wrong. OOPS.
Old Jan 9, 2008 | 01:55 PM
Mirage2.0's Avatar
I'm actually losing 1.8 PSI but that I will see on my own in 2 hours, lol.
Old Jan 10, 2008 | 05:57 AM
Mirage2.0's Avatar
Damn guys. Finally I felt the boost in my own mirage.
To be honest I was kind of scared to hit it about 4700 rpm, lol. Torque is so amazing. In 1st and 2nd gear, my steering wheel was going all over the place.
On Saturday I'll make a vid for you guys.
Old Jan 10, 2008 | 08:49 AM
krnzzang84720's Avatar
Congrate Mirage!!! I am glad you came through!!!
Enjoy!!! BOOSTING
Old Jan 10, 2008 | 08:55 AM
Mirage2.0's Avatar
Yea, I still have to find out why I'm not seeing full boost. Alot of testing over the weekend.
Old Jan 10, 2008 | 10:59 AM
ambystom01's Avatar
Oh torque steer, how I don't miss you, lol.
Old Jan 10, 2008 | 11:11 AM
Mirage2.0's Avatar
Hey it's a great feeling, lol.
Old Jan 10, 2008 | 11:12 AM
ambystom01's Avatar
Don't worry I understand, there are times when a little wheel spin is fun.
Old Jan 10, 2008 | 11:30 AM
Mirage2.0's Avatar
Hey, put little more money into wrx and you can notice that in awd also.
Can't wait until I go to the track. 6.5 psi = 13s all day
Old Jan 12, 2008 | 10:34 AM
cincy's Avatar
Ill believe that when i see it. Oh, and if you want tq steer, drive a audi/vw with 230-250wtq before 3k with fwd
Old Jan 12, 2008 | 11:57 AM
ambystom01's Avatar
Yeah 13s seem a bit unrealistic unless you run slicks or something like that.
