turbo help
Old Mar 18, 2008 | 05:38 PM
sheezy'sES's Avatar
turbo help
i just recently put a turbo kit on my 03' lancer es. it's a turbo specialties t25 intercooled turbo kit. i bought this used, but it almost new condition. anyway, when i put the kit it was seeing like 15lbs of boost from the guy before. i have the wastegate tied open as far as it will go, so i'm only seeing like 3-4lbs, 5 on a cold morning. anyway, my exhaust is popping when i'm hard on it and i have to get out of it. i can floor it in 1st, but then it pops right about 2nd and really bad if i stay into it in 2nd. i really can't drive the car hard at all, because i don't wanna blow up my motor. someone said it could be a fuel filter, someone else said it could be i need to restrict my exhaust. i had headers on the car before, so i have no cats and a 3" apexi n1 muffler. i'm looking to upgrade my setup, i have everything i need, rx7 460cc injectors, walboro 255 fuel pump, apexi safc, and just put on a new bov. just wanted to ask for a little help...turbo is new to me, so i don't know a whole lot about it, but i'm learning. i just want my car faster and running safely, with no worries about damaging my engine. so, if anyone can give me some ideas or advice, please do...i don't no of any turbo lancer around here in greenville, SC, so i'm reaching out for help. thanks.
Old Mar 18, 2008 | 05:41 PM
lancer2show's Avatar
do you have wideband. mines pops at times too due to rich conditions
Old Mar 18, 2008 | 05:43 PM
sheezy'sES's Avatar
no just an autometer air/fuel gauge
Old Mar 18, 2008 | 06:00 PM
ambystom01's Avatar
Could be the BOV.
Could be an injector issue.
Could be a tune issue.
Could be a wastegate issue.
Old Mar 19, 2008 | 06:23 AM
Mirage2.0's Avatar
I bet it's his tune or no tune.
Old Mar 19, 2008 | 09:01 AM
ambystom01's Avatar
That's what I was thinking but from the sounds of it, more things could be wrong as well.
Old Mar 19, 2008 | 09:20 AM
lancerrally45's Avatar
does it pop like a backfire? if so you could be pre-igniting the mixture in the cylinder.
Frankracer88's Avatar
ya my car is turbod too. Itl pop sometimes when im on it if i rip through a gear. I have 440cc injectors and walboro pump and im only running about 5 psi. i also have a wideband. i have used evoscan to try to figure out exactly what it is. Im pretty sure that it is just some unburnt fuel in the exaust thats burning up on the inside of the exaust. My car has been dyno tuned so im pretty sure that if you tune itl go away a little but expect it on the top a little when you get on it no matter what.
Old Mar 19, 2008 | 04:56 PM
SLVROZ_03's Avatar
Okay man, time to update that avatar! LOL Well, I was fortunate enough to meet and know this young man in my town and was able to help out with the BOV install this past weekend. The setup is pretty nice actually; I had never known there was a cast manifold for the lancer! Guessing it's probably a Mirage mani, but it looks great.
Okay, about your issues. The popping is probably due to the car running just an FMU and stock ecu. The car is seeing rich conditions during the gear change and thus the pops. Oh, btw the car is automatic. He does have an I/C.
The exhaust you have is fine, you want the fewest restrictions on it as possible. 3" is prefect from the downpipe back.
Okay, now about tuning. Who has tuned their car on a SAFC? Is it possible on this Apexi unit? Besides this unit, what all would you guys recommend? ECU Flash? RRM piggy? Etc etc.
Old Mar 19, 2008 | 08:09 PM
id be using a wideband with evoscan and ecuflash, but thats me.
Old Mar 23, 2008 | 02:32 PM
sheezy'sES's Avatar
i basically wanted to know from someone, kinda what my setup was and if i use a walboro 255 fuel pump, 89-91 rx7 460cc injectors, and an apexi safc, if this was going to be an alright way to go to get a little more power out of my car?? i wanted to ask the popping in my exhaust to see if anyone else had this problem. a buddy of mine swears its the fuel filter and it's not getting enough fuel, because i go lean, but it seemed to clear itself out for him, so that's why he thought it was my fuel filter. anyway, anyone who's used an safc to tune there lancer, i just kinda wanted to know a little more about it, before i just have it put on. and if the injectors i'm going to run would be ok. i'd like to run 8 or 9 lbs, but i want to be safe too...this is my everyday driver, but i want it to run right and be a little faster. right now i'm going very slow because i can't put my foot to the floor without a pop from the exhaust and i have to let off...it's no fun at all. again, anyone with some advice again would be very much appreciated. thanks.
Old Mar 24, 2008 | 06:08 PM
SLVROZ_03's Avatar
Free bump for you bud!
Old Mar 25, 2008 | 09:04 AM
senate6268's Avatar
For starters you should have a wideband installed before you do any permanent damage to anything. You would be fine to run a Walbro, 460cc's and tune with an SAFC. But, please get rid of the Autometer A/F gauge. It serves a better purpose as a light show than an actual means of tuning.
Old Mar 31, 2008 | 05:53 PM
sheezy'sES's Avatar
just wondering if anyone could explain to me more about evoscan?? and a little more about ecu flashing?? looking into getting the aem wideband. just broke at the moment. just wanted to know more about what to do once i get everything together. don't really know of anyone with a turbo lancer here in greenville, SC and just want to know if i take it somewhere knowledgable with they be able to install everything and set it up the correct way, or how i need to go about tuning my lancer for more boost. any advice would be helpful. thanks.
Old Mar 31, 2008 | 06:09 PM
ambystom01's Avatar
ECU flashing involves refining the stock code to allow for a more ideal AF ratio. If you haven't tuned before, don't try it now.
