Custom Turbo on a 2006 Lancer ES... Lots of modifying!!!
Fuel pump is a super easy swap. Pop your back seat bottom out and there will be a plate screwed down. Remove that and you'll see the fuel pump housing top with the fuel sending hose and a plug. undo both of those and unbolt the top and you can then pull out the assembly. from there you will be able to remove the pump. The actual pump is the same as the old lancer. The assembly is the only thing different. It just has a return hole on it. No lift needed. Take a look and you'll see how easy it is.
Jeez, you probably saved me like a week of garage work, thanks man!!! That will be so much easier now. thanks again
Alright.... I finally got the lancer running decent. I got the 255 installed along with my 460cc injectors...... I was able to keep along side of a C4 corvette up to 95mph..... pretty damn impressive. I'm still running rich though so a tune will get it much faster. I will get some pics up soon once i make sure everything is working ok. Also if any of you read my oil thread, I am now using Royal Purple and will never go back........ Yep, it sure blows up engines! anyways I hope I can get the lancer looking as good as it is fast, still waiting for the wheels. I also need to remount the intercooler back towards the motor and up a bit to fit my evo8 bumper.
^first off that pull to 95mph with that vette was of course done on a closed course as we all know... You said your using 460cc injectors? What are they from, just curious, and do they fit with only a little spacing of the fuel rail bolts? Cant wait till you get some pics of your setup. ON WITH IT!!!
Yeah... closed course...
haha. Yeah I think the injectors are fom an RX7????? I beleive thats what the guy said... anyways as I have tried to tell others that post about just using "longer bolts", you do need longer bolts but you also have to slot the fuel rail mounting bolts.... think about it, the injectors sit at an angle, right? so if you make them longer, not only is it going to move them higher, but also towards the firewall..... so to compinsate you have to slot the holes on the fuel rail closer to the rail itself, that way you can get the bolts to line up and you dont cross thread anything
. I need to get this car tuned though!! It sits at a 10.0 AFR under full throttle and almost all the time except idle. I need to get that fixed soon!
haha. Yeah I think the injectors are fom an RX7????? I beleive thats what the guy said... anyways as I have tried to tell others that post about just using "longer bolts", you do need longer bolts but you also have to slot the fuel rail mounting bolts.... think about it, the injectors sit at an angle, right? so if you make them longer, not only is it going to move them higher, but also towards the firewall..... so to compinsate you have to slot the holes on the fuel rail closer to the rail itself, that way you can get the bolts to line up and you dont cross thread anything Thread
BlackOperative
Apr 7, 2009 11:40 PM
AfireINSIDE
Apr 26, 2007 04:24 PM
