turbo timing maps
Old Sep 27, 2008 | 11:20 AM
Complink's Avatar
turbo timing maps
could someone who uses ecuflash for a 16g on mostly stock motor running 6-8 psi post a picture of Hi/lo octane timing maps? I would like to compare to mine just to get an idea if i'm headed in right direction.
Old Nov 9, 2008 | 06:13 PM
sykou's Avatar
Why don't you post some of your maps so we can all benefit from this thread. You can get some useful advice from some people on here regarding ecuflash.
Old Nov 10, 2008 | 09:17 PM
Complink's Avatar
I only retarded the timing a little after i reflashed the ecu to stock and i havn't datalogged it either so im probably getting some knock.
Old Nov 14, 2008 | 09:06 PM
sykou's Avatar
your maps seem a bit jumpy in the higher rpms.... do a WOT log and see where you get knock. The ECU will retard timing to "X" when it sees more than three counts of knock. go to your maps and enter in "X" where the ECU pulled back timing...The Timing that the ECU is using is the ideal timing it wants so give it that. If you reduce your timing you may also have to lean out the mix a bit as less timing requires less fuel... You wanna try to get a smoother transition throughout the entire timing maps....
Old Apr 20, 2009 | 04:18 AM
Complink's Avatar
sykou, could you post a pic of your timing maps? also how much boost are you running?
Old Sep 4, 2009 | 11:00 PM
ThunderOZ's Avatar
bumping this for help...
Old Sep 6, 2009 | 12:24 AM
Complink's Avatar
this is the one im using
Evo_Goodness
Aug 30, 2016 04:00 AM
NitroWD
Jun 11, 2016 11:01 PM
Charlescrown
Apr 29, 2015 01:52 AM
5LEEPERISAH23I
Aug 4, 2010 09:23 AM
merlin.oz
Dec 19, 2008 04:40 AM
