what would i need if i bought this?
Old Oct 16, 2008 | 12:38 PM
m3ta11ica12345's Avatar
ok so lately ive been really looking into turboing my car. the RRM kit just simply isnt an option b/c i dont have the cash for it. so i found a kit thats basically a bare bone kit without any extras. i think its a good kit cuz it gives me somehting to get started on and i can easily upgrade later. so i have three questions...
1) what would i need if i wanted to buy this kit then upgrade it to include an IC and BOV and where could i get the piping/hoses/clamps etc.?
2) if i wanted to buy a bigger turbo (16G probably) and swap that in what other parts would i need?
3) how much boost could i run on a t25 and 16g turbo if i got new rods and pistons?
heres the kit im lookin at - http://www.prostreetonline.com/pnsku/ml2501.asp
Old Oct 16, 2008 | 08:16 PM
doctorjon's Avatar
1) The kit your looking at is a for 5 to 6 psi safe boost. I've seen some integras run 7 with no intercooler. You could goto any local muffler shop or buy a intercooler/piping kit on ebay. Make sure you get a RECIRC BOV also.
2) I don't think the manifold can fit a 16G, but i am certain RRM manifolds can fit the 16g turbos.
3) BBT25 is rated about 250 to 300hp. Gives you quicker spools at lower RPM, but can't really give you high boost at higher RPM.
The EvoIII 16g is rated to +400hp it can achieve higher boost levels at higher RPMS.
I would look into turbocharging and do a lot of research.
Old Oct 17, 2008 | 06:57 AM
ok so if i wanted to switch to a 16g turbo i would only need a manifold?
Old Oct 17, 2008 | 08:48 AM
b00tl3g93r's Avatar
Off the top of my head you would need manifold, o2 housing, downpipe, and a wastegate. would you be getting a evo III 16g or another one?
Old Oct 17, 2008 | 09:06 AM
i was planning on gettin the evo III one from rrm but whats the difference?
Old Oct 17, 2008 | 09:14 AM
b00tl3g93r's Avatar
evo 8 and 9 are twin scroll is what i'm told. Evo 3 isn't. lol.
Old Oct 17, 2008 | 09:21 AM
twin scroll? wtf does that mean lol
Old Oct 17, 2008 | 09:23 AM
bcollinstex's Avatar
single turbo with two exhaust inlets
Old Oct 17, 2008 | 09:24 AM
b00tl3g93r's Avatar
http://wiki.answers.com/Q/How_does_a...bocharger_work
Old Oct 17, 2008 | 09:35 AM
oh ok that helps alot. but yeah i thikn i want the evo III one
Old Oct 18, 2008 | 05:19 PM
cincy's Avatar
the 16g comes in either the twin scroll or the 14b flange that first gen dsm's used. You would need to replace everything since they are far from compatable. There are many T25 turbos out there that are better than a 16g but they will cost you more. But thats not going to make any difference until you have a completely built engine and preferably another a 7k redline
Old Oct 20, 2008 | 09:38 AM
are the more expensive t25s better hten the more expensive 16Gs?
Old Oct 20, 2008 | 11:32 AM
ambystom01's Avatar
The 16G will have the higher output but which is better is debatable.
Old Oct 20, 2008 | 01:47 PM
if theyre both about hte same im thinkin i should go with the 16G just because its bigger and i heard thd t25 sounds too stock
Old Oct 20, 2008 | 01:57 PM
ambystom01's Avatar
? Your car didn't come with a turbo so I don't understand how it could sound "stock". Bigger isn't always better.
